Migrate from Chameleon to Cover bootloader - Help
Hello, I´ve a Laptop Asus K55VM with dual boot fully working: Windows 8 + Mavericks.
My HDD is partitioned with MBR sectors in 3 partitions:
Mavericks -> HFS+
Win8 -> NTFS
Data -> NTFS
I´ve installed Chameleon on Mavericks partition and when boot computer i have to select system to init. All works perfectly. Now, I´d like to test Clover bootloader. Could did I install it on the Mavericks partition and replace Chameleon without format HDD??? Does Clover work on MBR partitions with normal bios??? Is required to install Clover on GPT partitions??
Thanks!!
if u have uefi bios.. to boot must be in gpt
in a normal bios.. u can install clover to boot in legacy mode..
my advice is to prepare a usb pen to boot and test..
when u have all properly then install it in the hd
