djpowertrip Posted December 6, 2013 Posted December 6, 2013 Hi everyone:-) I am old Hackintosh boy but i assembled last one on Asus P5B in 2008 i think or 2009..doesn't matter....it was not easy at this time:-) but lot of guys from different forums helped me to do it....and i work with it till yesterday...and he was gone ....RIP:-)) Now i have Retail Snow Leopard and Gigabyte mobo GAX38 DQ6 and ati 5770 graphic card...RME Hamerfall HDSP 9652 audio card I try o install it with Empire EFI bootloader but graphic is not working ( i have only 1024x576) resolution and quite wrong recomended hardware ( Intel Xeon instead of Intel Quad core etc etc...) only the network adatper working fine.... The most important thing is that i need support for dual screen video.... Is there any suggestions to fix this computer? I really need it for serious job...i must replace my old Hack with this one and now i have a problem... Any suggestion will be appreciated... THX in advance....
artur-pt Posted December 6, 2013 Posted December 6, 2013 hello 10.6.3 and ati 5xxx series no go.. no support .. update to 10.6.8 and then should work u graphics http://Olarila.com/forum/viewtopic.php?f=28&t=736 good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
BeJimmiegenry Posted September 23, 2019 Posted September 23, 2019 I would try it in another machine to see if its a bad card, otherwise it could be a problem with the mobo. If you can, try the other pci slot first. If by Gigabyte menu you mean a splash screen that covers up POST messages, turn it off in the bios to see what its stopping at. dragon crib sheets
