Just built new PC and trying to install Mavericks for the past 2 days...
finally got past loading drivers, now stuck at kernel panic, cant capture the screen, but it says something about UiMiIntiliaze invalid number of root hub ports??
Also something about AppleHDA failed to load??
Currently runnning Kubuntu and ran the system info from your site, everything checked out as ok for my system
Ive tried some of the boot flags suggested from your site, but no luck
(cpus=1,USBBusFix=yes, npci,graphicsenabler,PCIrootuid, -x -f -v)
Any suggestions?
thanks
My setup
Mainboard-Asus Z87-plus
CPU Intel i5-4670k
GPU-ATI Radeon HD4850
SSD-Corsair 128GB
RAM-Corsair 16GB 2133 DDR3
something about this and that don't help
post detailed info
from boot
don't expect a easy install
what u use to boot .. loader
Ok got a little further, seems to be a problem with USB kext, so removed them, now stuck at waiting for root device, so i tried 3rd party AHCI kext, no luck??
see attached screen shot
any advice?
thanks
As for more info ok
I am using Olarila OS X Mavericks USB bootable image from TPB
I have tried both chameleon and clover boot options
for the kernel panic problem i removed these
/OS X Install USB/EFI/CLOVER/kexts/10.8/GenericUSBXHCI.kext
/OS X Install USB/System/Library/Extensions/backup/IOUSBFamily.kext
that got me past the kernel panic, but stuck at waiting for root device
did some more research saw some people had success with 3rd Party AHCI kext, so i added that to the Extensions folder...but it did not work. Also tried AHCIDisk=1. npci=0x2000 and (0x3000), dsdt=null, usekernelcache=no, USBBusFix=yes
none of these options have made a difference...maybe you have something i don't know
thanks
if u remove the iousbfamilly .. how the usb works ?
xHCI Mode see how options u have in bios , try to set to auto
xHCI Hand-off / EHCI Hand-off see if are enabled
how to set the bios
asus-pdf.zip
http://www.insanelymac.com/forum/topic/290187-asus-z87-deluxe-4770k-a-guide-to-mavericks/
thanks for the info but the link u referenced requires a working mac, which i do not have...there is good info there but most are post install issues i cant even get to the installer; still stuck at waiting for root device. i know there is a fix as i have seen many people with this issue resolved, but i cant seem to get it working
as for the usb issues i got it worked it with the bios changes you suggested.
thanks i keep looking
