Hello. I have an EFI that works perfectly in Monterey. I have made some changes but it is impossible to install VENTURA. I need help, I feel unable to see the problem. I don't know if it's because the hardware isn't compatible. My hardware is: Intel I219V2 PCI Express Network, ASUS Z170-PRO motherboard, AMD Radeon RX 560 Compatible graphics card, (Metal GPUFamily macOS 2). I would be very grateful if someone could tell me the problem or modify the EFI. Thank you very much
config.plist.zip
