EckoNode Posted July 17, 2022 Share Posted July 17, 2022 (edited) Just for anyone having issues with your USB Bluetooth after updating to Monterey. My current spec is below: MacOS Monterey 12.4 TP-Link UB-400 USB dongle Opencore 0.8.2 SMBIOS iMacPro1,1 Kext used: BlueToolFixup.kext, BrcmFirmwareData.kext, BrcmPatchRAM3.kext, BrcmBluetoothInjector.kext Patch version that works: BrcmPatchRam-2.6.2-RELEASE.zip PC SPECS: Dual Boot Windows 11 & MacOS RTX 3060 TI OC (use Intel UHD 630 for mac) Intel Core i7 9700k ASUS H310M-E 2.0 RAM: 16GB You can find more details here. Edited July 17, 2022 by EckoNode Link to comment Share on other sites More sharing options...
webma Posted September 14, 2022 Share Posted September 14, 2022 @EckoNode My bluetooth is BCM 4350C2 how you managed to fix it? Link to comment Share on other sites More sharing options...
fritz122 Posted November 8, 2022 Share Posted November 8, 2022 (edited) Hi @webma I managed to get Bluetooth with BCM 4350C2 on Monterey and also on the latest Ventura 13.1 beta1 with Open Core 0.8.3 If you want to know how I did it, please write me an answer here. Greetings Fritz122 Edited November 8, 2022 by fritz122 Link to comment Share on other sites More sharing options...
Jalbert Posted November 9, 2022 Share Posted November 9, 2022 Hace 20 horas, fritz122 dijo: Hola@webma Logré obtener Bluetooth con BCM 4350C2 en Monterey y también en la última versión beta de Ventura 13.1 con Open Core 0.8.3 Si quieres saber cómo lo hice, escríbeme una respuesta aquí.Saludos Fritz122 Guia Plis!! Link to comment Share on other sites More sharing options...
cruz97808 Posted November 13, 2022 Share Posted November 13, 2022 hello @fritz122 I have the same issue I was wonder if you could share how you did it. Rn I have the Bluetooth showing that it it on however it doesn't work when i go to the settings. Wifi works flawlessly I'm just having issues with the Bluetooth part of it. Link to comment Share on other sites More sharing options...
fritz122 Posted November 25, 2022 Share Posted November 25, 2022 On 13.11.2022 at 09:00, cruz97808 said: hallo@fritz122Ich habe das gleiche Problem, ich habe mich gefragt, ob Sie teilen könnten, wie Sie es gemacht haben. Rn Ich habe das Bluetooth, das anzeigt, dass es eingeschaltet ist, aber es funktioniert nicht, wenn ich zu den Einstellungen gehe. Wifi funktioniert einwandfrei, ich habe nur Probleme mit dem Bluetooth-Teil davon. Ich habe einfach das Port Limit auf "false" nicht auf "true" gesetzt und dann ging auf einmal BT Link to comment Share on other sites More sharing options...
Oruj Posted March 6, 2023 Share Posted March 6, 2023 On 11/25/2022 at 7:47 PM, fritz122 said: Ich habe einfach das Port Limit auf "false" nicht auf "true" gesetzt und dann ging auf einmal BT Hi. Can you please tell me where I have to set port limit to "False" ? In which file? Or can you give me any youtube or tutorial link for this issue? Link to comment Share on other sites More sharing options...
tanfouss Posted June 17, 2023 Share Posted June 17, 2023 On 11/8/2022 at 4:57 PM, fritz122 said: Hi @webma I managed to get Bluetooth with BCM 4350C2 on Monterey and also on the latest Ventura 13.1 beta1 with Open Core 0.8.3 If you want to know how I did it, please write me an answer here. Greetings Fritz122 how did you do this? Can you take a picture Link to comment Share on other sites More sharing options...
