crusher Posted November 4, 2013 Posted November 4, 2013 Please help I have a big problem via Wake after sleep.Worked until I turned off the PC and removed from power cables from my PSU. This is my proble for Wake Up.I write this command on terminal...... syslog |grep -i "Wake reason" -Mac-Pro kernel[0] : Wake reason: GLAN XHC -Mac-Pro kernel[0] : Wake reason: PXSX But after this command this message..... pmset -g Active Profiles: AC Power 2* Currently in use: standby 1 Sleep On Power Button 1 womp 1 autorestart 0 hibernatefile /var/vm/sleepimage darkwakes 0 networkoversleep 0 disksleep 10 sleep 10 (sleep prevented by coreaudiod) autopoweroffdelay 14400 hibernatemode 0 autopoweroff 1 ttyskeepawake 1 displaysleep 10 standbydelay 4200 Speedstep work greate.......Sleep work same........Please help........ After sleep mode pc turn on but no picture on my monitor.Only turn off monitor. Thank you.... I attach my DSDT.aml!!!!! DSDT.aml.zip Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
crusher Posted November 4, 2013 Author Posted November 4, 2013 (edited) I put later my org.chameleon.boot.plist in here. This my org.chameleon.boot.plist. smbios.plist.zip Edited November 4, 2013 by Guest Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
artur-pt Posted November 4, 2013 Posted November 4, 2013 hello u have wifi card ? i think is that causing wake problems.. good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
crusher Posted November 4, 2013 Author Posted November 4, 2013 No I don't have a WIFI card in my PC. Do you have more ideas. Thanks..... Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
artur-pt Posted November 4, 2013 Posted November 4, 2013 hello so is the lan what kext are u using ? see about that kext.. good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
crusher Posted November 4, 2013 Author Posted November 4, 2013 (edited) I'm using this kext.Maybe change. AR8151 v2.0 Gigabit Ethernet, en0 Look I install new OSX but after turn off compjuter and unplug all the cables After that sleep work and wake but don't turn on monitor. Thanks..... IONetworkingFamily.kext.zip Edited November 5, 2013 by Guest Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
crusher Posted November 4, 2013 Author Posted November 4, 2013 Look my speedstep working OK. Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
pernacabeluda Posted November 6, 2013 Posted November 6, 2013 Try these patches in devices EHC1, EHC2 and XHC http://Olarila.com/forum/viewtopic.php?f=2&t=34&start=100#p32870 DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
crusher Posted November 6, 2013 Author Posted November 6, 2013 Im found EHC1 but don't find Device XHC.Please put in my DSDT this patches.I add EHC1 patch. Thank you!!!!!! DSDT.aml.zip Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
pernacabeluda Posted November 6, 2013 Posted November 6, 2013 It's attached in my previous post. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
crusher Posted November 6, 2013 Author Posted November 6, 2013 Ok thank you!!!!I don't see... Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
crusher Posted November 10, 2013 Author Posted November 10, 2013 I turn off my PC and after Turn On Work,but don't turn on my monitor after sleep....Maybe error my sound card or whatever? This is my DSDT!!!!! DSDT.aml.zip Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
pernacabeluda Posted November 10, 2013 Posted November 10, 2013 Did you try the DSDT I attached? The one you posted has only the USB patch in EHC1, not in EHC2 and XHC. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
crusher Posted November 10, 2013 Author Posted November 10, 2013 I've tried with your DSDT is loaded in a previous post Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
crusher Posted November 10, 2013 Author Posted November 10, 2013 This is my error..... Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
crusher Posted November 10, 2013 Author Posted November 10, 2013 (edited) Help!!!!This is my RunMe,IORegistryExplorer and DSDT file..... Thank you...... Ibragic’s Mac Pro IORegistryExplorer.zip Send me Ibragic’s Mac Pro.zip DSDT.aml.zip Edited November 12, 2013 by Guest Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
crusher Posted November 10, 2013 Author Posted November 10, 2013 Any help please.....But dont work and this.Don't see my both graphics card.Please help. http://www.insanelymac.com/forum/topic/286474-about-using-discrete-and-integrated-graphics-at-the-same-time/ I try but don't luck. Thank you... Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
crusher Posted November 11, 2013 Author Posted November 11, 2013 Why no one will help me????? Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB
regae Posted November 25, 2013 Posted November 25, 2013 for me i have to remove this line, it works for me at least Method (WAK, 1, NotSerialized) { \_SB.PCI0.LPCB.SWAK (Arg0) \_SB.PCI0.NWAK (Arg0) LEDW (Arg0) \_SB.PCI0.LPCB.SIOW (Arg0) << remove this line } become this Method (WAK, 1, NotSerialized) { \_SB.PCI0.LPCB.SWAK (Arg0) \_SB.PCI0.NWAK (Arg0) LEDW (Arg0) }
