Hackintosh macOS Ventura Beta 3 Solution - Clover or OpenCore
Hello ,
The Ventura was installed by OC , all are OK , except track pad ELAN 1300 .
I tried to use Clover from Olarila (Notebook 100,200 (KBL-R )), but   I have bootloop on the Ventura , and change quickly and  I have not time to see nothing .
On the last , Monterey I used Clover and  I have not any problem all was OK , I used  also same Clover from Monterey but is not running  I think Clover for Ventura is different .I update all kext , but the result is negativ.
what processor?
6 hours ago, inter said:
i5 8250U  (KBL-R)
need check if this elan need some extra patch
On my SSD , I have the following volumes "
/dev/disk2 (synthesized):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      APFS Container Scheme -                      +199.4 GB   disk2
                                 Physical Store disk0s4
   1:                APFS Volume Ventura HD - Data       26.0 GB    disk2s1
   2:                APFS Volume Ventura HD              8.8 GB     disk2s2
   3:              APFS Snapshot com.apple.os.update-... 8.8 GB     disk2s2s1
   4:                APFS Volume Preboot                 1.8 GB     disk2s3
   5:                APFS Volume Recovery                1.1 GB     disk2s4
   6:                APFS Volume VM                      1.1 MB     disk2s5
When I use Clover Bootloader , on the boot option I have only the Volumes Preboot and Volume Recovery  ,the  Ventura HD   is missing and I can not boot .
The Ventura HD     has  a protection and can not read by Clover ?
On the OC all are OK .
The boot partition is Preboot
Hi , I need your help .
On my laptop I have SSD  1T  -Macos and SSD 500 G Win 11 .
Today I format  SSD 1T (Ventura  ) due to clean install  because  I has been many problems  .
1.Now I can not boot win 11 , from SSD 500 G , because to boot I used Clover (Monterey ) and  win 11 boot drive was in EFI SSD 1T .
Please advice if I can restore the  win 11 boot  drive to SSD 500 G  to boot from BIOS .
2. I tried to reinstall Ventura , but now at clean install I have ,bootloop  , my EFI start to Install , copy the files (about 40 min) and after restart  can not continue by install due bootloop , and is moving quickly and I have not time to see the errors .
Please send to me a EFI folder ,for my laptop (i5-8250U '"KBL-R"  Intel UHD  620) ,I downloaded from the site , but is not running ,boot loop from the beginning .I used both OC and Clover
I need the Win 11 , because at my job , I have software which is running only windows OS ,till now I used Clover +Monterey and all was OK ,but now after update to Ventura start the problems .
Maybe is my mistake to early  update the new os  Ventura .
Thank you for your help .
By Ventura I tried all possibility , but unsuccesful , I did all your suggestion .
I installed back Monterey  , all are OK , except SSD boot , I can not boot from SSD M2 , on the BIOS UEFI from SSD M2 is  missing .Maybe you have a suggestion for this .
The volume EFI is on the SSD  M2 , I  copy/pate EFI folder from USB installer , but is not on the Boot option from BIOS .
Now I will use the USB to start the Monterey , I have not idea , but probably the problem is on the SSD or missing  the boot path .Now I do clean install I delete all from SSD  by Disk Utility  ,new partition .
i installed again Monterey to see if I have hardware problems ,maybe on the future I will dismantle my laptop  to clean and I will check the SSD M2 , maybe I will use another tool to  erase & Format the SSD .
