Hackintosh EFI for HP OMEN 15-en0xxx
Can anyone send Hackintosh EFI for HP OMEN 15-en0xxx
cpu: AMD RYZEN 5 4600H
motherboard: HP 8786 22.58
Edited by elon
forget it
What i tried failed , i tried both using a virtual box and also using dual boot. But virtual box was giving errors and restarts installing, while for dual boot it loads my windows 11 even when i select boot from usb.
i successfully installed macos 10.15.5 on virtual box on amd ryzen 5 4600h. But it didnt work directly to create a boot with it.
i have other laptop - hp pavillion 15 i7 8550u, 12gb ram, integrated graphics and touch screen, can i install macos on it with dual boot of windows 11 ?
Also if working, can you send efi files and also what problems i may have with it like touchpad, touch screen, keyboard, mouse, wifi, etc ?
Edited by elon
