You need NullCPUPowerManagement in EFI/CLOVER/kexts/10.9 and InjectKexts=true.
but... where is EFI/CLOVER/kexts/10.9 ?
I boot in single user verbose mode and i search EFI/CLOVER but i don't found.
If i open the pendrive with TransMac i don't found. :(
If you are using the image from this topic, the kext is already there, in EFI partition, just boot with injected kexts which is default.
grgrgrgr :( not work!!!
i do this.
mount my usb in a linux
sudo mount /dev/sdc1 aa
i copy this dir : NullCPUPowerManagement.ktext
david@david-kubuntu:~/aa/EFI/CLOVER/kexts/10.9/NullCPUPowerManagement.kext/Contents$ ls
Info.plist MacOS Resources
Info.plist contents
CFBundleDevelopmentRegion
English
CFBundleExecutable
CFBundleIdentifier
org.tgwbd.driver.NullCPUPowerManagement
CFBundleInfoDictionaryVersion
6.0
CFBundleName
CFBundlePackageType
KEXT
CFBundleSignature
CFBundleVersion
1.0.0d2
IOKitPersonalities
IntelCPUPowerManagement
CFBundleIdentifier
IOClass
IOMatchCategory
AppleIntelCPUPowerManagement
IOProbeScore
100
IOProviderClass
IOResources
IOResourceMatch
IOKit
OSBundleLibraries
com.apple.kpi.iokit
8.0.0
com.apple.kpi.libkern
8.0.0
com.apple.kpi.unsupported
8.0.0
OSBundleRequired
Root
Save and umount and i boot my notebook
CLOVER OPTIONS
Boot Args: -v cpus=1 npci=0x2000
boot by my netbook restarts :(
any suggest?
thks
Which installer are you using? Are you booting with injected kexts?
If you are using the image from my link, you don't need NullCPUPowerManagement because it has the Disabler kext.
