vahids Posted October 17, 2013 Posted October 17, 2013 Hi, It's work by VoodooHDA but it's buggy. I used this kext and DSDT modification : http://www.osx86.net/files/download/76-applehda-for-alc269/ but not helped. My laptop is acer e1 571g and core i3 osx 10.8.5
Mirone Posted October 17, 2013 Posted October 17, 2013 Try this: http://www.osx86.net/files/file/607-alc269-acer-5745g-applehda/
vahids Posted October 17, 2013 Author Posted October 17, 2013 Try this: http://www.osx86.net/files/file/607-alc269-acer-5745g-applehda/ Thanks! It's working... Speaker working well. Headphone (Jack) Working well. Microphone (Jack) Working. Laptop Microphone not work. HDMI Audio not work.
vahids Posted October 17, 2013 Author Posted October 17, 2013 and in Every boot Sound is disable and I need to run this command in terminal: sudo kextload /System/Library/Extensions/AppleHDA.kext to Enable Sound
Mr.KiLLeR Posted October 21, 2013 Posted October 21, 2013 Thanks! It's working... Speaker working well. Headphone (Jack) Working well. Microphone (Jack) Working. Laptop Microphone not work. HDMI Audio not work. can you tell me how it works for you not me i have the same Sound with same OSX too in System profile it saying Layout-ID : 4 , can you please patch my DSDT by any chance ?? if you can check if my DSDT is patched correctly ?? DSDT.aml.zip Acer Aspire v5-571P Intel Core i5-3317U @ 1.70GHZ 6GB RAM 500GB HDD Windows 8 64Bit
vahids Posted October 22, 2013 Author Posted October 22, 2013 can you tell me how it works for you not me i have the same Sound with same OSX too in System profile it saying Layout-ID : 4 , can you please patch my DSDT by any chance ?? if you can check if my DSDT is patched correctly ?? Sorry mine stop working. I'm trying to patch AppleHDA from scratch but stock on extract Verb Data OK, let me explain: It's my codec detailes from Linux: Node 14 : Pin Default 0x99130110: [Fixed] Speaker at Int ATAPI , EAPD 0x02 Node 18 : Pin Default 0x03a19830: [Jack] Mic at Ext Left Node 19 : Pin Default 0x411111f0: [N/A] Speaker at Ext Rear Node 21 : Pin Default 0x0321101f: [Jack] HP Out at Ext Left to extract Verb Data in first step I should replace data: Node 14 : 10 01 13 99 Node 18 : 30 98 a1 03 Node 19 : f0 11 11 14 Node 21 : 1f 10 21 03 I don't have any Idea what it the next step :/
ACS79 Posted December 12, 2013 Posted December 12, 2013 Pessoal, estou tentando habilitar meu áudio usando AppleHDA para ALC 269. Minha HDEF ficou assim? Device (HDEF) { Name (_ADR, 0x001B0000) Method (_DSM, 4, NotSerialized) { Store (Package (0x08) { "codec-id", Buffer (0x04) { 0x3E, 0x29, 0x00, 0x00 }, "layout-id", Buffer (0x04) { 0x0D, 0x01, 0x00, 0x00 }, "device-type", Buffer (0x11) { "ALC269" }, "PinConfigurations", Buffer (0x2C) { /* 0000 */ 0xF0, 0x11, 0x11, 0x41, 0xF0, 0x11, 0x11, 0x41, /* 0008 */ 0x10, 0x00, 0x13, 0x90, 0x40, 0x40, 0x21, 0x01, /* 0010 */ 0xF0, 0x11, 0x11, 0x41, 0x30, 0x90, 0xA1, 0x01, /* 0018 */ 0x50, 0x00, 0xA3, 0x90, 0xF0, 0x11, 0x11, 0x41, /* 0020 */ 0xF0, 0x11, 0x11, 0x41, 0x60, 0x80, 0x03, 0x40, /* 0028 */ 0x20, 0x00, 0x43, 0x90 } }, Local0) DTGP (Arg0, Arg1, Arg2, Arg3, RefOf (Local0)) Return (Local0) } } 1) Mostra o audio em informacoes do sistema, porem ainda o audio nao funciona, veja as imagens abaixo: Segue o Ioregistry 10.8.5 | 10.9.5 : GA-X79-UP5 | Intel LGA 2011 | Core i7 3820 | GTX660 TI | ALC898 10.10.3 : GA-Z97X-UDH5 BK| Intel LGA 1150 | Core i7 4790K | GTX970 | ALC1150 | TP-Link TL-WDN4800 | USB Bluetooth Comtac
Mirone Posted December 12, 2013 Posted December 12, 2013 você esta usando uma kext antiga de lion tente uma das kexts para ALC269 deste tópico: http://Olarila.com/forum/viewtopic.php?f=9&t=1933 tem um Arquivo LEIAME para informar as mudanças no HDEF do seu DSDT.
ACS79 Posted December 12, 2013 Posted December 12, 2013 Mirone, já tentei essas kexts também e sem sucesso. O mais próximo que cheguei foi o que está postado no site e verifiquei que as informações contidas no PinConfurations é que mostra as minhas configurações de áudio em informações do sistema. Já tentei de tudo e o áudio ainda não trabalha. 10.8.5 | 10.9.5 : GA-X79-UP5 | Intel LGA 2011 | Core i7 3820 | GTX660 TI | ALC898 10.10.3 : GA-Z97X-UDH5 BK| Intel LGA 1150 | Core i7 4790K | GTX970 | ALC1150 | TP-Link TL-WDN4800 | USB Bluetooth Comtac
PimentelX86 Posted December 12, 2013 Posted December 12, 2013 Olá Se AppleHDA não funciona para você, tu podes tentar usar VoodooHDA 2.8.4 Download: http://www.projectosx.com/forum/index.php?showtopic=355
Mirone Posted December 12, 2013 Posted December 12, 2013 @AC579 me envia seu codec_dump+dsdt+ioreg.ioreg.
ACS79 Posted December 13, 2013 Posted December 13, 2013 Mirone segue o link dos arquivos solicitados para audio do Dell 1564. https://www.dropbox.com/sh/sviuh7gw28pg75r/rixqY0VYgd?lst 10.8.5 | 10.9.5 : GA-X79-UP5 | Intel LGA 2011 | Core i7 3820 | GTX660 TI | ALC898 10.10.3 : GA-Z97X-UDH5 BK| Intel LGA 1150 | Core i7 4790K | GTX970 | ALC1150 | TP-Link TL-WDN4800 | USB Bluetooth Comtac
Mirone Posted December 14, 2013 Posted December 14, 2013 @ACS79 tenta essa; instalar applehda+dsdt. http://www.sendspace.com/file/8kw91p
ACS79 Posted December 16, 2013 Posted December 16, 2013 Mirone infelizmente não funcionou. Essa kext já é a configurada para o meu notebook? Se alguém puder me ajudar a resolver esse problema, eu agradeço... 10.8.5 | 10.9.5 : GA-X79-UP5 | Intel LGA 2011 | Core i7 3820 | GTX660 TI | ALC898 10.10.3 : GA-Z97X-UDH5 BK| Intel LGA 1150 | Core i7 4790K | GTX970 | ALC1150 | TP-Link TL-WDN4800 | USB Bluetooth Comtac
