see in about this mac what is the video being used. if intel hd3000 delete the other video kexts and repair permissions. and make sure that you install the kexts from the pendrive that you remove to install or the kexts in the system can be without info.plist and it won't work.
also, if you have system info check your dev id of the intel hd 3000. i can help you to get it working, just see if it is the intel hd active.
HI.
I think IntelHD3000 and SNB is being used. I think its active. I check the terminal via
kextstat
and i saw the SNB and HD3000 loaded. I double check ofcourse by removing the NVDA kext(i create a backup of it just in case) and booted via
GraphicsEnabler=Yes
and it still works
Everything is working fine i guest but i still have that glitchy thing on notification menu and the open gl problem.
The device ID of my intel graphics card is
1026
