Hi there,
I am one step closer to have my mac :D
Ive installed every kext compatible to me. like voodooHDA and for the keyboard(VoodooP2scontroller), and the intel HD3000 kext
I first boot to HDD(w/0 usb stick) with -v -x GraphicsEnabler=No cpus=1
and also -f
but all i got is the SNBFramebuffer not show up issue
Restart and boot to HD(w/0 usb) again.
move the AppleIntelHD* and AppleIntelSNB* kext manually by booting to single user(-s) to a backup folder
Use the same command.
-v -x GraphicsEnabler=No cpus=1 -f
The SNBFramebuffer is gone but im stuck with this
Then I reinstall the kext again by booting to HDD with USB stick. Still i got the error of SNBFramebuffer(1st picture abov).
Intelhd3000 is compatible to my system. So im not sure why i cant get to the graphical environment?
This is a laptop btw.(HP)
I am using MacBookPro 8,1 SMBIOS
Can anyone help?
Hello.
In your signature say you have Nvidia graphic.
So i guess you have Dedicate+Integrate graphics(Nvidia+Intel 3000)
So why you want use HD 3000 if you have a dedicate Nvidia Graphics?
You can disable your integrate graphic on Bios, but you can't disable your Nvidia Graphics(Dedicate)
I think your issue is just because this. You need use Nvidia Graphics.
Please don't create a new topic every time you have a problem, use the same topic for all questions.
Hello.
Ow ok.. Since my NVidia is not compatible and theres no available kext does that mean that its a dead end?
is a notebook
it can disable intel hd 3000 is in cpu
Hello.
No? Why?
He has two graphics, Integrated and Dedicated.
HD 3000 is in CPU, but… I disabled my HD 2000 to make my GT 610 work.
I guess Notebook and PC don't have a minimal difference in this case.
Please explain this to me artur.
Hello.
No. All kext are in mac, you don't need add nothing.
If your kext doesn't work you need edit it.
What is your Nvidia Graphic?
I am using Nvidia GeForce 630M?
is not the same thing..
desk bios and notebook bios..
optimus thecnology don't work in mac os x
note bios don't have option to disable integrate graphics..
why so many lappy users .. use intel hd 3000 or 4000
because the intel is the primary card.. and u can disable it in bios.. and mac os x don't do the switch between the 2 cards..
thats why
man no way will work.. read about the issue
Hello.
Ok, ok.
All thing are explain now.
So artur... You have a solution to him? I don't have. :(
No solution? :(
Do you still want to get my ven Id Graphics card?
Hello.
Post it.
Post NVDAGF100Hal.kext and your DevID and VenID.
I don't know this i'll work, but i'll try.
Hi.
This is my ID
Vedor ID: 10de
Device Id: 0de9
About the kext. When i boot to -x i reach the Log in screen and when i goes to desktop environment it just freezes. I tried also the command like -v GraphicsEnabler and -f cpus=1 Still the same.
Hello.
I'll edit my kext and add your ID's.
You will have to install it through the terminal installation.
Ok.. Thanks..
Just give me kext and instructions then im good to go :D
Hello.
The forum support only 1Mb and kext have 1.5Mb
I will post it in other host tomorrow.
After i give to you more instructions.
Okay. Thank you very much. I'll wait for it. For now ill just stick to windows. BTW im just curious how did you learn coding kext?
If you don't have an option to disable integrated graphics in BIOS setup, the nVidia won't work.
To get Intel HD 3000 working
http://Olarila.com/forum/viewtopic.php?f=28&t=2193
Hello.
Reading and making things
My graphic card doesn't working on 10.8, so i had to edit it to work.
I started editing by necessity.
I am not expert, but I can make things right when i want.
Good idea, i don't know why i don't think it.
But if you want i put in here the edited kext.
Hello.
Hi. i just want to remind you about the kext :D
Yup already tried it. Delete and reinstall the kext. still cant get to desktop GUI. It happens when i boot to HDD only. Although i dont know why when i boot to HDD(using USB) i can get to Desktop GUI.
