(Solved) BT works, but WiFi is not working
I have purchased this card BCM943602CS, the Bluetooth works okay without any kexts whatsoever. But when it come to Wifi, nothing seems to work even if i add the Airportbcm kext, nothing works. Has anybody gone through this situation to help out @MaLd0n Attached below are the images of the card.
Edited by dudewith
brcmfx-delay delays start of native broadcom driver for specified amount of milliseconds. It can solve panics or missing wi-fi device in Monterey. You can start with 15 seconds (brcmfx-delay=15000) and successively reduce this value until you notice instability in boot.
https://github.com/acidanthera/AirportBrcmFixup
@MaLd0n help here bro, I can't turn on wi-fi or BT, used the boot args mention none. ps am using premade EFI for Skylake made by you.
this card need fake device id
use 43a0
use 43a0
where should I add this fake device id? please
u can use device properties or acpi to inject it
@MaLd0n you talking to a noob here...let's go device properties here..so this "43a0"  goes here? pic below
17 minutes ago, dudewith said:
Brooooooo!!! May you live long!! it worked..Thanks, i will make sure i buy a beer.
Enjoy!
