iDont Posted September 24, 2013 Posted September 24, 2013 I was having a boot issue on HD(still waiting for root device error) not on the HD from usb stick. I installed the IOACPIntel kext to address the problem. Now it gives me a kernel panic every time i boot the HD and the HD using usb stick. I tried the single user mode (-s ) but still gives me the kernel panic. I tried the very common command such as -s -x -f -v cpus=1 GraphicsEnabler=no No luck still kernel panic. this is the Screen shot Is there a fix for this or do i have to reinstall the whole OS? i just want to delete the kext on my HD
artur-pt Posted September 24, 2013 Posted September 24, 2013 hello boot the installer terminal cd /Volumes/VOLUMEname/System/Library/Extensions rm -rf name.kext good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
iDont Posted September 25, 2013 Author Posted September 25, 2013 hello boot the installer terminal cd /Volumes/VOLUMEname/System/Library/Extensions rm -rf name.kext good hack Hello. It gives me read only.
PimentelX86 Posted September 25, 2013 Posted September 25, 2013 Hello. Try it: cd /Volumes/VOLUMEname/System/Library/Extensions sudo rm -rf name.kext
iDont Posted September 25, 2013 Author Posted September 25, 2013 Hello. Try it: cd /Volumes/VOLUMEname/System/Library/Extensions sudo rm -rf name.kext Hi. It says: "sudo command not found"? should reinstall the osx?
PimentelX86 Posted September 25, 2013 Posted September 25, 2013 Hello. should reinstall the osx? Isn't necessary. Try: cd /Volumes/VolumeName rm -rf ./System/Library/Extensions/nameofkext.kext If this doesn't work, try: rm -rf /Volumes/VolumeName/System/Library/Extensions/nameofkext.kext Good Luck!
artur-pt Posted September 25, 2013 Posted September 25, 2013 hello u can try also boot -s and then mount the volume fsck -fy mount -uw / and then apply the commands good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
