Hello,
I want to install macOS Monterey on this desktop pc :
- AsRock H370M-itx/ac
- Intel Core i3 8100
- Intel UHD Graphics 630
- Corsair Vengeance LPX 16 Go (2x8 Go) DDR4 2400MHz
- SSD M2 Nvme Samsung
I have create a usb install key with createinstallmedia command.
I have tried to boot with your Clover and OpenCore folders for Mobos Serie 300.
The pc boots but after a few seconds, the screen turns off and I have to reboot the pc.
Can you help me?
use -igfxvesa
Hi,
Thank you for your help :)
I added -igfxvesa and was able to install.
I had to add the kext SATA-unsupported for the installer to detect my SATA hard drives and the installation on a SATA hard drive went well.
But now when I start the computer to finish the installation process, the pc restarts by itself when I have to choose the language.
Do you know what the problem is?
Thank you very much for your help
what nvme samsung u have
this nvme need a updated firmware. check it
Hello,
I have updated the firmware of the SSD but there is still the same problem.
I have two hard drive in RAID1 :
Could they cause the problem?
U need test without it for check
Hi,
I installed with default BIOS settings (RAID disabled).
The first part of the installation of macOS Monterey works then I interrupted the installation because the computer was restarting about fifteen times without succeeding.
I tried to install macOS Big Sur and it works but graphics acceleration is disabled.
Big Sur works with Samsung EVO 970 SSD plugged in and RAID1 is seen correctly.
I don't know what to do to make it works with monterey : can you help?
I can make a donation if you want to fix the problems
Edited by mapomme
u need create ur video patch
we can fix with telegram. check here about that
https://www.olarila.com/topic/7717-important-premium-and-donators-users/
Hello,
I will create a video patch
Is it possible you tell me why it is working with Big Sur and not with Monterey?
update kexts and bootloader and go
Hello,
I have installed macOS Monterey with Clover and it works :)
I have no graphic accelaration,
I have changed SMBIOS to iMac 19,1
I have added this boot arguments
igfxonln=1
and this device properties in config.plist
	<dict>
		<data>BwCbPg==</data>
		<data>AQAAAA==</data>
		<key>framebuffer-con0-enable</key>
		<key>framebuffer-con0-alldata</key>
		<data>AQAJAAAEAADHAwAA</data>
		<key>framebuffer-con1-alldata</key>
		<data>AgAKAAAEAADHAwAA</data>
		<key>framebuffer-con2-alldata</key>
		<data>AwQIAAAIAADHAwAA</data>
		<data>AAAwAQ==</data>
		<key>hda-gfx</key>
		<string>onboard-1</string>
		<key>name</key>
		<string>Intel UHD Graphics 630</string>
	</dict>
but it does not work
Can you help?
Edited by mapomme
I have added ig-platform-id and set shared memory to 256Mo but there is still no hardware acceleration
Edited by mapomme
Hello,
Thank you Kernel for your link.
Ventura works with graphic acceleration.
but Bluetooth does not work : I can activate it but it does not search for devices so there is no device in the list,
Can you help me?
I have followed this guide
