Monterey installation OpenCore 0.8.0 Panic - please help
My specs:
Drive: SSD ADATA XPG NVMe 1TB
Processor: i7-9700KF, 3.6 GHz (No iGPU)
External GPU: ASRock Radeon RX 550 2GB (Patched in config.plist)
MB: Asus z390-p PRIME
RAM: HyperX Fury RGB, DDR4 3200Mhz
Im trying to install OpenCore Monterey, even created and fully patched SSDT'S - still no luck.
The installation goes smoothly in the beginning.
First restart at 12 min remaining in MacOs Installation screen.
After restart 29 minutes remaining goes to 20 minutes and restarts again after that i get this panic screen:
This hardware configuration was working before on Catalina - wanted to make a clean start with Monterey.
Please help.
Here is my EFI:
https://drive.google.com/file/d/15AhsGyrh81m2ULTqYgZmNzU9-43_eYYP/view?usp=sharing
use bios/uefi in default, just disable csm
I did reset the bios to default settings and only disabled CSM.
It bootloops when continuing the installation on this:
