crusher Posted September 20, 2013 Share Posted September 20, 2013 Some help for my sound card...Does not work out for the pink microphone, so we need a proper patch for it. Thanks..... Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB Link to comment Share on other sites More sharing options...
crusher Posted November 11, 2013 Author Share Posted November 11, 2013 I now have a DSDT patch for my Audio Card VIA 2021 Device (HDEF) { Name (_ADR, 0x001B0000) OperationRegion (HDAR, PCI_Config, 0x4C, 0x10) Field (HDAR, WordAcc, NoLock, Preserve) { DCKA, 1, Offset (0x01), DCKM, 1, , 6, DCKS, 1, Offset (0x08), , 15, PMES, 1 } Method (_PRW, 0, NotSerialized) { Return (GPRW (0x0D, 0x04)) } Method (_DSM, 4, NotSerialized) { Store (Package (0x06) { "hda-gfx", Buffer (0x0A) { "onboard-1" }, "layout-id", Buffer (0x04) { 0x0C, 0x00, 0x00, 0x00 }, "PinConfigurations", Buffer (0x30) { /* 0000 */ 0x10, 0x40, 0x11, 0x01, 0xF0, 0x00, 0x00, 0x40, /* 0008 */ 0xF0, 0x00, 0x00, 0x40, 0xF0, 0x00, 0x00, 0x40, /* 0010 */ 0xF0, 0x00, 0x00, 0x40, 0xF0, 0x00, 0x00, 0x40, /* 0018 */ 0x50, 0x30, 0x81, 0x01, 0x60, 0x90, 0xA1, 0x90, /* 0020 */ 0xF0, 0x00, 0x00, 0x40, 0x20, 0x21, 0x45, 0x07, /* 0028 */ 0xF0, 0x00, 0x00, 0x40, 0xF0, 0x00, 0x00, 0x40 } }, Local0) DTGP (Arg0, Arg1, Arg2, Arg3, RefOf (Local0)) Return (Local0) } } Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB Link to comment Share on other sites More sharing options...
PimentelX86 Posted November 11, 2013 Share Posted November 11, 2013 Hello Do You want patch HDEF to use AppleHDA? Sorry man, but VIA VT codec work better with VoodooHDA Download version 2.8.4: http://www.projectosx.com/forum/index.php?showtopic=355 Only download, install and remove AppleHDA or install AppleHDADisabler... Many things work natively with VoodooHDA in VIA codec, i believe your mic will work too I have VIA VT 1705 codec and everything was recognized using VoodooHDA Good Luck! Link to comment Share on other sites More sharing options...
crusher Posted November 11, 2013 Author Share Posted November 11, 2013 Ok.I will now try to do it your way... Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB Link to comment Share on other sites More sharing options...
PimentelX86 Posted November 11, 2013 Share Posted November 11, 2013 Hello Note: VoodooHDA isn't necessary patch DSDT, work without patch. Advice: Install with Kernel Wizard and update cache. Link to comment Share on other sites More sharing options...
crusher Posted November 11, 2013 Author Share Posted November 11, 2013 Now remove DSDT patch or not.What you think? Mobo: GA-Z90 M Gaming CPU: i9 9900K RAM: 16GB Kingstone NVMe: Samsung 970 250GB SanDisk SSD: 500GB Link to comment Share on other sites More sharing options...
Mirone Posted November 11, 2013 Share Posted November 11, 2013 try this: http://www.insanelymac.com/forum/files/file/154-applehda-for-via-vt2020vt2021-1085/ Link to comment Share on other sites More sharing options...
PimentelX86 Posted November 11, 2013 Share Posted November 11, 2013 Hello Now you can choose 1- Install vodooHDA and reomove AppleHDA and doesn't patch HDEF(You can remove only HDEF patch of DSDT, leaving untouched the needed patch for your mobo) 2-Install this AppleHDA and does't install VoodooHDA, but patch HDEF... Choice is yours now... Link to comment Share on other sites More sharing options...
