maikeln Posted September 15, 2013 Posted September 15, 2013 Hi, my problem is when startup hackintosh, bluetooth dont work, only when press FN+F3, activate and work, I can activate bluetooth when start hackintosh? Thanks Is a laptop Acer 5820tg with 10.8.5 and bluetooth device: Versión del Software Bluetooth Apple: 4.1.7f2 12718 Ajustes del hardware: Dirección: 50-63-13-FA-E6-BE Fabricante: Broadcom Nombre: MacBookPro Versión del firmware: v119 c21341 Alimentación Bluetooth: Act. Modo visible: Desactivado Conectable: Sí Activación remota: Act. ID del fabricante: 0x0489 ID del producto: 0xE011 Versión HCI: 0x4 Revisión HCI: 0x535D Versión LMP: 0x4 Subversión LMP: 0x4277 Tipo de dispositivo (mayor): Ordenador Tipo de dispositivo (completo): Ordenador portátil Mac Clase de dispositivo compuesta: 0x38010C Clase de dispositivo (mayor): 0x01 Clase de dispositivo (menor): 0x03 Clase de servicio: 0x1C0
asusg73 Posted September 19, 2013 Posted September 19, 2013 You have to add your device id into IOBluetoothFamily, show package contents, plugins, and the first kext you see which since you have Broadcom will be, BroadcomBluetoothHostControllerUSBTransport.kext. Again right click, press show package contents, and copy info.plist to desktop. I can either tell you how to do it or you can attach your info.plist and ill edit for you.
maikeln Posted September 19, 2013 Author Posted September 19, 2013 Hi friend, attach file with a mirror, 3 files into zip. https://mega.co.nz/#!xNww3ABJ!OaO0Sl83WiRm1cafVwuUGmahQV0T4MUlezZjA0NSsR0 https://www.dropbox.com/s/2bravbszw1nm8ze/Archivo%20comprimido.zip Thanks
asusg73 Posted September 19, 2013 Posted September 19, 2013 Here you go friend! BroadcomAppleBluetooth.kext is not needed for native bluetooth functionality. But if you do want to use it i patched that and IOBLuetoothFamily.kext. First try only IOBluetoothFamily by itself first and let me know how it works. Thanks! https://www.dropbox.com/s/hsd80c2268lyz7s/Archivo%20comprimido.zip EDIT: IOBluetoothHIDDriver only controls bluetooth mice and is generic so no change there. Be sure to remove BroadcomAppleBluetooth.kext first!
maikeln Posted September 20, 2013 Author Posted September 20, 2013 Hi, now when press fn+f3 bluetooth activate very fast, but don't auto activate when start mountain lion. Thanks
asusg73 Posted September 20, 2013 Posted September 20, 2013 Hi, now when press fn+f3 bluetooth activate very fast, but don't auto activate when start mountain lion. Thanks Hmm...now try adding BroadcomAppleBluetooth.kext and post results...did you install a DSDT?
maikeln Posted September 20, 2013 Author Posted September 20, 2013 same with two files Attach dsdl.aml in post thanks dsdt.aml.zip
asusg73 Posted September 20, 2013 Posted September 20, 2013 same with two files Attach dsdl.aml in post thanks Hmm...what does the bluetooth icon show when you first boot up? Does the bluetooth still activate after sleep? Go into terminal and type kextstat so i can see which kexts you have installed.
maikeln Posted September 20, 2013 Author Posted September 20, 2013 when boot up, bluetooth dont show on preferences. After press fn+f3 activate bluetooth and icon show on preferences Sin título.tiff
asusg73 Posted September 20, 2013 Posted September 20, 2013 when boot up, bluetooth dont show on preferences. After press fn+f3 activate bluetooth and icon show on preferences Ah ok. I used to get that when i wake up from sleep...it usually means the driver is initializing...it should come on after a minute or so? I wish there was a way fn+f3 could be turned into a script but im not very good with coding Maybe its a kext that is interfering. Open terminal and type "kextstat" (no quotes) and post screenshot. Thanks for your patience!
maikeln Posted September 20, 2013 Author Posted September 20, 2013 http://pastebin.com/e25fAbuL thanks friend
