hemmingway Posted April 11, 2022 Posted April 11, 2022 (edited) Hello, the installation of Catalina with EFI.Opencore.Desktop.AlderLake.MOD stucks. What can I do? The screenshots are attached. Is GA RTX 2080ti the problem? Greetings, Bernhard GA Z690.zip Edited April 13, 2022 by hemmingway Add additional infos
Administrators MaLd0n Posted April 11, 2022 Administrators Posted April 11, 2022 try https://easyupload.io/3frgli use usb2 port -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
hemmingway Posted April 13, 2022 Author Posted April 13, 2022 This EFI works fine. I can boot former installations of Monterey and Catalina. I install Catalina from boot stick on a partition with former Catalina. There I run the RunMe App. Please send me a DSDT Patch for my hardware. Greetings, Bernhard Send me Bernhards-iPro.Z690.zip
Administrators MaLd0n Posted April 13, 2022 Administrators Posted April 13, 2022 https://easyupload.io/nictmv this nvidia dont work. u need change this card remap usb https://www.olarila.com/topic/14220-hackintosh-usb-port-mapping-guide-2021-2022-mojave-catalina-bigsur-monterey/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
hemmingway Posted April 13, 2022 Author Posted April 13, 2022 (edited) This EFI works fine for me. Ethernet, WiFi, Audio, Video Streaming, Audio Streaming work. Monterey works better than Catalina. For software development is the machine excellent. I do not need video acceleration. Thank you for my saved time. Greetings, Bernhard Bildschirmfoto 2022-04-13 um 20.19.09.zip Edited April 13, 2022 by hemmingway 1
Administrators MaLd0n Posted April 13, 2022 Administrators Posted April 13, 2022 Very nice -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
hemmingway Posted April 15, 2022 Author Posted April 15, 2022 (edited) I have a small issue: While starting OC a line with SerialInit occurs. What can I do? SerialInit.zip Edited April 17, 2022 by hemmingway
Administrators MaLd0n Posted April 15, 2022 Administrators Posted April 15, 2022 is just some new quirks/config with last opencore version. just wait release and we fix it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
hemmingway Posted September 22, 2022 Author Posted September 22, 2022 Hello, I want to update my system to 0.8.4. (Copying the new files into EFI folder) I got a Windows BSOD screen with ACPI_BIOS_ERROR. What is wrong? Smaller problems are: I prefer round icons and not squashed icons, See Startup.zip. Also a startup sound is missing . Can you help me?? Please send me a DSDT Patch for my hardware. The RunMe App is started on monterey. Send me Bernhards-Z690.new.zip Startup.zip
Administrators MaLd0n Posted September 23, 2022 Administrators Posted September 23, 2022 post ur full efi folder here with one ioreg -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
hemmingway Posted September 23, 2022 Author Posted September 23, 2022 The files are attached. EFI.zip iMac Pro.zip
Administrators MaLd0n Posted September 23, 2022 Administrators Posted September 23, 2022 first lets clean and update things https://easyupload.io/hikoc4 -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
hemmingway Posted September 24, 2022 Author Posted September 24, 2022 Booting Monterey stucks after ~5 percent. Booting Catalina stucks after ~10 percent. Windows 11 runs fine. What can I do?
Administrators MaLd0n Posted September 24, 2022 Administrators Posted September 24, 2022 1 hour ago, hemmingway said: What can I do? https://olarila.com/files/OPENCORE.MOD1/EFI.Opencore.Desktop.AlderLake.MOD.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
hemmingway Posted September 24, 2022 Author Posted September 24, 2022 Here are the screenshots Catalina_Monterey.zip
Administrators MaLd0n Posted September 24, 2022 Administrators Posted September 24, 2022 update bios to last version use bios in default settings, don't change nothing -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
hemmingway Posted September 26, 2022 Author Posted September 26, 2022 With optimized defaults. Monterey_ Catalina.zip
Administrators MaLd0n Posted September 26, 2022 Administrators Posted September 26, 2022 https://www.transfernow.net/dl/20220926ELnFuV2c reset nvram one time -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
Administrators MaLd0n Posted September 26, 2022 Administrators Posted September 26, 2022 15 minutes ago, hemmingway said: I've done that before. this folder above have changes. test it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
hemmingway Posted September 27, 2022 Author Posted September 27, 2022 Catalina and Monterey start up and work fine. The desktop runs fast and smooth. That's fine. 1
hemmingway Posted September 28, 2022 Author Posted September 28, 2022 Bildschirmfoto 2022-09-28 um 19.06.21.zip
Administrators MaLd0n Posted September 28, 2022 Administrators Posted September 28, 2022 1 hour ago, hemmingway said: Bildschirmfoto 2022-09-28 um 19.06.21.zip 28.79 kB · 1 download Looks good -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
hemmingway Posted January 11, 2023 Author Posted January 11, 2023 Hello, I have updated my System to an i9-13900k and GA Z790 UD AX. Everything works fine for me, but no audio. What can I do? Greetings, Bernhard Send me GA Z790.zip
Administrators MaLd0n Posted January 12, 2023 Administrators Posted January 12, 2023 https://www.transfernow.net/dl/202301123KQnonLQ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
