so, I used the vanilla Monterey image and the coffee lake EFI
I have a
i9 9900
msi z390m motherboard
sapphire rx 6600 xt
I was able to get it installed and can boot to macOS desktop
the issue im having is that the wifi/bluetooth is not being detected so I have no interwebs and I aslo have no multi monitor.
I run a display port in a daisy chain configuration.
thanks in advance
disable csm on bios/uefi
So after looking around last night. I don’t think my wifi/Bluetooth card in my msi z390m is compatible it’s an Intel® Wireless-AC 9560
https://www.msi.com/Motherboard/mpg-z390m-gaming-edge-ac/Specification
I was also unable to get my 2nd monitor to show up. Even though both screens were mirrored. In macOS it would only show one on the display tab
I will try again using the new kexts. Ty
Edited by indecentseas
so great news.. bluetooth and wifi are now working..
im sure there are more issues I have yet to discover. but I think the most pressing issue is to be able to extend my monitors. currently both are driving off of a single DisplayPort using a daisy chain configuration and I can see the same screen mirrored on both monitors. however when I look at the displays window in system preferences only one shows up.
so doing a bit of research online I've read conflicting threads about if MST/daisy chained monitors via display port actually work in Mac OS. can anyone confirm if it's supported? if not I can always run another DP cable and get the other monitor working. but the setup would be a lot cleaner with one cable.
so I ended up just running another dp cable.. I suppose the last thing to do is to tweak the system and remove unused kexts etc.. and remap the usb. can anyone point me to a decent guide / video on how to remap usb and remove unused kexts and clean up my EFI so that it only has entries pertaining to my system.
thanks a lot.
usb mapped successfully. doing this actually resolved a few issues I was experiencing; like mouse stuttering. obviously USB ports not working. and a more stable bluetooth/wifi..
I guess my next question is how do I fine tune the system now and remove unecesarry kexts / ssdts etc..
Thanks in Advance.
post ur efi folder with one ioreg
could you explain a bit why MacPro1,1 is better and what do you mean by hardware acceleration, also what changes did you do please.
also I ran this through OCAuxTools and got the following.
OCS: No schema for EnableForAll at 0 index, context <Quirks>!
OCS: No schema for EnableForAll at 6 index, context <Quirks>!
OCS: No schema for ForceAquantiaEthernet at 10 index, context <Quirks>!
OCS: No schema for SkipCustomEntryCheck at 11 index, context <Boot>!
OCS: No schema for LogModules at 5 index, context <Debug>! Serialisation returns 5 errors! Completed validating /Users/*******/Downloads/EFI/OC/config.plist in 0 ms. Found 5 issues requiring attention.
Thanks in advance.
I can confirm. everything is working as it was before. I haven't noticed anything different between IMacPro19,1 vs MacPro1,1 I did noticed Traktor 3, Machine 2, Mashup, Mixed In Key "appeared" to load the audio spectrum a bit faster. but that could be placebo. I do get a bit of stuttering from time to time with my Bluetooth. but it's not a game breaker. it's very infrequent
if u used iMac19 smbios u need enable Internal Graphics for intel quick sync, with iMacPro1,1 or MacPro7,1 smbios u dont need enable IGPU
fair enough. I don't use sidecar on my desktop so I'm not missing out on anything anyways. I appreciate all of your help.
I'm really impressed with how the system runs. I've been running gnome on multiple distros for years and I feel right at home on this hackintosh.
once again I appreciate you shoulder surfing me.
I'll be sending another donation your way.
Enjoy!
