Hello there!
I'm obviously new to the forum... and as you will understand when reading - new to hackintoshing.
I managed to install and run - quite successfully if I may say - OS X on an Ivy Bridge AsRock B75 Pro3-M MoBo.
Whatever I did though, I couldn't get sound to work. That is why I did some googling and came across Olarila. I found a DSDT file that was requested by a user with the same motherboard as mine and installed it. That's exactly when my installation crashed. I tried changing my BIOS version (someone told me that mattered for DSDT files), tried various kernel boot flags, but nothing worked, so now I'm stuck.
I guess after all I said my question is: Is there a way out of this situation, or should I be re-installing instead of wandering around the web?
Cheers!
P.S. I tried getting a "clean" DSDT and loaded it on boot. Didn't help a notch.
dsdt is like under ware .. never use from another.. rsrsrs
boot without it.. if it works before...
about sound 2 solutions
voodoohda
http://Olarila.com/forum/viewtopic.php?f=28&t=454
applehda
http://Olarila.com/forum/viewtopic.php?f=9&t=1933
Hello!
Turns out maybe my sound kext turned out to be the problem. I deleted AppleHDA.kext and /Extra/*.mkext
Then my system booted with -v -f Flags. Graphics are awful and still no sound, but I surely won't stop digging around.
Thanks for the answer and the links.
