Hi,
Specs:
i7 7700hq
12gb ram
Gtx 1050ti (disabled)
Intel wifi (works with airportitlwm)
MacOs Monterey 12.3
I used olarila cabylake notebook efi (removed unnecessary kexts and added needed ones)
Everything works except touchpad.
On windows touchpad looks like:
Manufacturer: synaptic
Bios device name: \_SB. PCI0.LPCB.PS2M
I deleted only unnecessary lan kexts.
I tried the mod efi too. The same result ebething works except touchpad.
And it's a little strange: When I disable voodooi2c kexts system won't boot and gives stop signal at Apple logo screen.
If any other Infos needed please tell mspacer.pnge.
Edited by coldchris
trackpad don't work?
4 hours ago, tasco11 said:
You have to identify what is your Touchpad type, PS2 or I2C.
In windows device properties :
plugged in ps/2 mouse port
So it must be a ps2.
However when I try to deactivate I2C kexts and activate ps2 kexts macos won't boot giving me stop signal. I think it's because of the ssdt.
