zornar Posted August 2, 2013 Posted August 2, 2013 I installed 10.8.4 with unishit. After the successful installation, the system will auto reboot... When it restarted I can choose there between my USB and HDD, but it doesn't matter if I type 1 or 2, it'll boot to the installer all over again so I can't procceed to the OS. I'm not really sure what to do, could anybody help me out here? Thank you very much
serneko Posted August 2, 2013 Posted August 2, 2013 I installed 10.8.4 with unishit. After the successful installation, the system will auto reboot...When it restarted I can choose there between my USB and HDD, but it doesn't matter if I type 1 or 2, it'll boot to the installer all over again so I can't procceed to the OS. I'm not really sure what to do, could anybody help me out here? Thank you very much Dont use tony's_hit, people love that sh_it though, ain't no sh_it at all. Try to do with this forum image/way
mendietinha Posted August 2, 2013 Posted August 2, 2013 type 1 or 2? you should select the hd with the arrow keys and press enter. as you may not notice before, there is no support for beasts here, it is not used here. Se quando viaja faz o que quer, quando viajar, não leve a mulher ---- No PM support. Use the forum..MBP 2012 I7 12GB 512GB (macOS 13.6.7 & macOS 15b) OCLP Lenovo Core I5 6200U 8Gb 256Gb HD520 (macOS 15b) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11)
Pockets69 Posted August 4, 2013 Posted August 4, 2013 As you may have noticed we do not endorse the use of any *beast stuff, if you want support for that software, you should go to where you got it. SteamBox - Intel Core i5 3570k, Gigabyte ga-z77n-wifi, Intel HD 4000, HDD 2TB, 8GB DDR3 ChromeBook Air - Intel Atom N450, Intel Integrated Graphics 3150, HDD 500GB, 2GB Ram
littlegreen Posted August 12, 2013 Posted August 12, 2013 Since I'm a total newbie and don't know anything about those beasts this may sound really dumb, but did you try booting without the USB stick in the computer?
zornar Posted August 12, 2013 Author Posted August 12, 2013 I stopped trying. I thought you had to press 1 or 2 to choose between usb and hdd, but you had to choose with the arrow keys. That was a bit stupid of me.. However, I could start up with the USB (in safe-mode), but not without.I would receive a weird error, I made a picture of it: So I tried many things on the internet, also things like copying some files from the usb to the hdd so I could boot.. But it didn't worked.. I will attach the error that I would receive when trying to boot from the HDD. I don't have a lot of experience on getting a hackintosh to work..
artur-pt Posted August 12, 2013 Posted August 12, 2013 hello remove the ati card and boot with hd 4000 about the ati , after install the system try to use clover to set the ati good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
zornar Posted August 12, 2013 Author Posted August 12, 2013 I tried to remove my GPU, but then I noticed my pc didn't show any screen when it was hooked up on the motherboard. So I did some research, and as how stupid I am, I bought the Intel core i5 3350P. This CPU doesn't have a integrated GPU.. so I'm a bit "screwed" now until I can buy a new processor.. and that will probably be next year.
artur-pt Posted August 12, 2013 Posted August 12, 2013 hello take a good read here http://Olarila.com/forum/viewtopic.php?f=28&t=736 and here http://www.insanelymac.com/forum/topic/284779-amd-7970-working-with-full-qe/ http://www.insanelymac.com/forum/topic/285756-hd-7xxx-can-we-eliminate-the-sleep-trick/ good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
