i found out which kext i need for my audio card 1e20 8086
i need voodoo hda 2.8.3 using voodoo loader and patcher
however i searched the internet and this forum couldnt find voodoohda 2.8.3
if you do have it please provide me with it
thnx
ok hi
i have installed voodoohda 2.7.3 from multi beast and i think im in progress
i can hear a really loud shooshing sound(nothing is played)
when i play anything there is no change in the shoooshh
i connected my headphones and i hear the shshshshsh in them
mute button work(shshsh is gone)
volume are displayed but dont make the shshsh lower
internal speaker doesnt work
i tried with many configuration in input gain and imix
i had a look in the topic voodoo common problems but couldnt specify my problem's solution
please reply!
device id 1e20 ven 8086
thnx
The gain is set to 90 by default. Change it to 0 in the info.plist.
And take a read in the voodoohda tread here in the forum.
MBA M5 (macOS 27)
Ryzen 9 5900X 64GB 5060TI 8GB 2Tb Nvme (macOS 15.8.3 - W11) OC
hi mendietinha...
my name is denny.
iam a newbie at hackintosh.
i tried to install an iatkos ml2 into my laptop aspire e1-471 (which is the same as
yours --> i read it at ur sig).
can you please help me to find the right kext for my laptop?
actually right now my wifi doesnt work.
or please help to send me the guide how to install it for dual booting with win 8.
because right now i couldnt boot without the helping of usb (clover bootloader inside
the usb).
really appreciate your help.
or...
btw, did install the maverick?
where can i download the good installer with all functional kext?
thank you very much
