Hello guys!
I have tried to install OS X on my Laptop the last year , but I got kernel panics , people tell me to give up with this project , because there's no QE/CI for Intel HD3000 , but then , I have saw some videos on youtube of people working on ML in their HP 630 Notebook , I was really excited to make it work on mine too.
I really need help to install it , BIOS settings are really limited, we can only test memory and choose the boot target.
I don't know which tutorial I have to follow. Please HELP :(
PC Specs :
i3 370-M
4GB RAM
Intel HD Graphics ( EDITED )
HDD 320Go ( 100Go for Windows , 100Go EMPTY For the futur Hackintosh , about 120Go for data )
THANKS !!
MSI H61M-P31/W8 • Intel Core i5 ™ 3470 @3,20Ghz • 8GB RAM • ZOTAC GTX1050Ti 4GB • DUALBOOT HIGH SIERRA/WINDOWS 10
yes! sorry :oops: that's it. thanks for the tutorial ! I'll follow once I install ML on my laptop.
How can I install it on my laptop ?
Thanks ! If it works ! I'll let you know
THANKS AGAIN ! QUICK ANSWERS ! THIS IS PERFECT ! :hatoff: :mrgreen:
After an attempt for install ML on my Laptop with tutorial that you gave me ! I have finally successed,
but now I have a problem concerning the drivers , I have no Airport, Bluetooth , for the QE/CI I'll install it with tutorial that you gave me later, SystemInfo requires JAVA , but no connection to install it :( what can I do ?
I do not really need Ethernet , but the WiFi connection
i removed tthe graphics on my drive with -s
i have hd 3000 but i haave 2nd generation core processor so is that guide going to be suitable for me?
if not can you provide me with a link that is going to work for me
my device id 0116
ven 8086
thnx
try with multishit for your version , I think that there is some kexts for Intel HD3000
ok then the only thing i can help you with
go to http://Olarila.com/kexts/
run systeminfo (download from the link)
search for your device id
then search in device id and enter your id number
you will find the kext you need... download it in system/library/extensions
donnt forget to repair permission
Audio : done !
Graphics : not else :/ I don't know how to install a bootloader
WiFi : installed kext , detect networks but it gives me an error while I insert the password :(
Tried to install the chameleon bootloader but i got this :(
try to use chameleon wizard and install the loader with option
boot0hfs
tried that , but same problem :(
finally got the bootloader work !
i have searched for a kext for my Wireless PCI Network Adapter AR9285 ( 168c - 002b ) and installed it , but when I want to connect , it's tells me "Connection Failure" any ideas ?
Audio : Installed
Graphics : Installed QE/CI
Bluetooth & Wifi Not else
everything is working like a charm except wifi . :( any solutions ?
EDIT :
Here is the results and what's I got
SEARCHED ABOUT , works only with WEP Keys , I'm gonna change onto WEP for the moment .
nothing , thanks for helping out !
maybe it will be useful for others :D
