Greetings, download monterey and the efi, however I am trapped in a kernel panic, my processor is i5-8250u kaby lake (laptop), UHD 620, if you could tell me the correct efi, I have already tried several with success
Edited by Marlonrm
use -igfxvesa
but that's for the GPU right? I get the installation screen and the disks fine, but when I touch the install button it doesn't happen, it just stays there as if waiting and the screen that I put is the log.
In the end it ended up being a bad combination of ssdt, I started to carry out tests and I already have an efi that loads in catalina without problems and raises the bigsur installer, starts the process and others, I will try to do a direct update
