kal-el88 Posted July 1, 2013 Posted July 1, 2013 (edited) Hi. I've finally got installed Mountain Lion on my Hackintosh PC: QX9650 GTX580 Maximus Formula Apple Keyboard Apple mighty mouse It seems to have recognoized the graphic card so i've the correct resolution, but i've some troubles to get audio and ethernet working. Which kext should I use? Which is the best DSDT I can get? the one from windows(AIDA) or from OSX? How can I edit correctly it for my Hardware? Thanks!!! Edited July 18, 2013 by Guest
artur-pt Posted July 1, 2013 Posted July 1, 2013 hello take a look here and read and googling.. in mac os x no easy installs http://Olarila.com/forum/viewtopic.php?f=28&t=1716 good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
kal-el88 Posted July 2, 2013 Author Posted July 2, 2013 Thank You for Your reply! I've managed to install ethernet using LegacyAppleYoukon2.kext editing the plist with my devID, the same i did for the Audio, i got it working using VoodooHDA for AD1988b editing with my soundcard devID. Now the last thing to do is to get sleep working. How can i do this? i've googled a bit but i found no working solutions...
artur-pt Posted July 2, 2013 Posted July 2, 2013 hello take a good read here http://Olarila.com/forum/viewtopic.php?f=28&t=1703 good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
kal-el88 Posted July 18, 2013 Author Posted July 18, 2013 After a bit reading, trying and reinstalling.. i've managed to get video natively working (without GE=yes), ehternet working only with legacy youkon 2, audio working with voodoohda 2.7.2... I've edited my DSDT and created an SSDT, i've achieved to get speed step and sleep working. I've only some minor problems: My Apple keyboard can't wake my system, i can wake it up only with mouse or power button. Restart isn't working after sleep.
