dovedescent7 Posted February 26, 2022 Posted February 26, 2022 (edited) Im like 76% sure i used this below guide to install. This software is AMAZING! Been Hackintoshing for years but this thing is GENIUS! Anyways, just have small issues. I only have 1gb of my 2gb of vram working on my Dell gt 720 2gb, this one https://www.ebay.com/itm/334305044863 Also i dont know how to move whats on flash drive to mac so that i dont need usb to boot. I want to remove usb! Thanks im new here is image of my About my mac https://ibb.co/hDPCqgm Edited February 26, 2022 by dovedescent7
Administrators MaLd0n Posted February 26, 2022 Administrators Posted February 26, 2022 i think is just cosmetic -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
dovedescent7 Posted February 26, 2022 Author Posted February 26, 2022 7 hours ago, MaLd0n said: i think is just cosmetic OK i understand. All set BTW the PC is HP Elitedesk 800 G1, Haswell i5-4590 HD 4600, GT 720 2gb GPU. Sole purpose of this machine is home video editing with Imovie and Final Cut Pro BUT... How do i address these Issues?? The Hackintosh suffers from random freezes (so bad that i need to force-shutdown, then restart) especially when using Clover Configurator. The good thing, the freezes aren't too often.. The other issue: The machine will just go into sleep mode, and i cannot wake it using my remote desktop connection. All fans shut off, and the machine doesn't even appear to even be powered on. How do i fix this? Lastly, my cousin just mailed me an RX 560 2gb, GPU INFO and should be here Monday. Should i install the 560 instead of the 720? And if using RX 560, should i just reinstall the OS/Olarila? And if so, should i use Monterey instead of the Big Sur that i am currently using? Does 720 or RX 560 even support HEVC codec?
Administrators MaLd0n Posted February 26, 2022 Administrators Posted February 26, 2022 1 hour ago, dovedescent7 said: Should i install the 560 instead of the 720? u need install rx560 and set smbios to iMacPro1,1 or u can use nvidia 720 but need enable intelHD for Intel Quick Sync -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
