Got my Asus Hero Maximus XIII with i9 11900K booted, partially working but issues with onboard audio and WIFI/BT persist!
Just tried doing an install of OC 0.7.8 and new updated plugins.  I have been using .asl files for the board which were released about a year ago that were supposed to map out the board audio and thunderbolt 4 port to no avail. Also both the Intel BT/Wifi .KEXT for Intel AX210 seem to not work.    Ethernet works - but switches between ports 0 and 1
Anyone have this board got the above issues fixed or have an EFI to share?
My build. MacOS12.2.1
  •  Asus Maximus XIII  with i9 11900K
  •  AMD 6900 XT
Use EFI folder from link bellow
https://www.olarila.com/topic/5676-hackintosh-efi-folders-for-all-chipsets-clover-and-opencore/
Check tutorial
https://www.olarila.com/topic/20908-guide-easy-fast-and-perfect-hackintosh-vanilla-step-by-step-clover-and-opencore-bootloader/
Some Basic Information
Bios/UEFI Configuration
-Use Load Optmized Default
-Sata = AHCI mode
-Secure Boot = Disable if need
-CSM = Disable with AMD cards
-If you have only IGPU use -igfxvesa bootarg for easy installation
Already tried the above methods.  It appears something changed in OC 0.7.x and up that breaks the IntelAX210 Wifi and BT connectivity with MacOS12 . I am asking as the above link about getting a hackintosh to load does not go into enough specifics on particular board hardware. ALC4082 seems to no longer work with AppleALC.
I have tried everything without much success.
My question is specific to a group of given Z590 boards with identical Audio, Intel WIFI/BT and Ethernet drivers.
Thank you.
So this EFI worked very well! Thank you. I can confirm 802.11AX is working and so is Ethernet (randomly disconnects) .  There are now 2 issues remaining,
1.Bluetooth still will not pick up nearby clients. Still not working.
2.Metal is not 100% supported.  My graphics card does not recognize as a 6900XT but rather a Navi12... weird.  m4v videos do not play correctly or show a low FPS. VLC doesn't work at all.
Sound works and shows up as RealtekUSB2.0 Audio and auto switches. The optical Audio port does not work.
Edited by Conor Whyte
Can you clarify the last values as to where they go?
BT is on in the system but still reporting as being:
Bluetooth Controller:
  Address: NULL
  State: Off
  Chipset: BCM_4350C2
  Discoverable: Off
  Firmware Version: v0 c0
  Product ID: 0x0001
  Supported services: 0x382039 < HFP AVRCP A2DP HID Braille AACP GATT Serial >
  Transport: USB
  Vendor ID: 0x004C (Apple)
Graphics issues still occur.
I disabled the iGPU -
6900XT is now running as primary.
this wifi card need fake id
I am running into issues with the graphics card not supporting metal. I have already changed the location of the graphics card using the unsupported graphics card method. When calling AMD  -  my card is on the compatibility list for eGPUs so it is not an incompatibility issue.
The bluetooth issue still remains as well as the comment didn't help nor the link.
can you go into some detail about what changed here? handing off a link is nice, but some explanation is needed.
does this address the issues with metal support?
Actually this EFI broke the Wifi/BT Ethernet and has reverted my card back to being a NAVI21.
I am going to stick with the other EFI I built as I had Wifi working.
 I am going to post my EFI as I am running into brick walls here... maybe somebody can help.  Throwing EFIs around isn't helpful if they aren't documented properly.
u need extract sendme with my efi folder
No. i don't need ur efi folder. Is a generic folder. here we don't use it.
U need use Olarila efi folder, reboot and extract one sendme for fine tune.
I figured out what you were asking of me.
I'll try with a plain version of your Olarila EFI for rocketlake and try to run the RunMe.app to get a complete system report for the Z590 Hero Maximus Hero XIII.
figured out your instructions.
Here is the file generated by the RunMe.app.
This was using the vanilla version - Olarila Rocket lake boot - using 0.79
Hopefully this contains all the files required to generate files for getting graphics card,BT and Wifi up and running.
I changed my graphics card's slot to give it more bandwidth.
It was sharing with an x4 NVMe drive
Send me iMac-Pro.7z
Great, work with this EFI folder !  Everything seems to be working, except BT5 which is running off the USB from the board. When reported the system profiler shows the card, but no driver support can be found even after setting up the KEXT for BT and the fake ID.  Other than that everything else is working.
I will send you a donation through paypal as you've helped a lot sir!
This means a great deal to me!
1 hour ago, Conor Whyte said:
except BT5
i think don't work. only 4
