Jacob Barry Posted February 23, 2022 Posted February 23, 2022 (edited) I have a i9-12900K, MSI Pro Z690-A mobo, Radeon RX6600 GPU, Using open core with the correct EFI Folder. I cant seem to get passed this screen. What am I doing wrong? Issue1.zip Edited February 23, 2022 by Jacob Barry
Administrators MaLd0n Posted February 23, 2022 Administrators Posted February 23, 2022 -Use USB2 port for easy installation with no remap USB -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Jacob Barry Posted February 23, 2022 Author Posted February 23, 2022 19 minutes ago, MaLd0n said: -Use USB2 port for easy installation with no remap USB -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - with OpenCore use entry "Reset Nvram" / with Clover use F11 key on boot screen I have been using the USB2 port on the back of the mobo. I deleted the old EFI and paste new EFI, reset NVRAM, and i get to the same part on the screen I am using the Alder lake efi folder download
Administrators MaLd0n Posted February 23, 2022 Administrators Posted February 23, 2022 https://easyupload.io/vg029s -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Jacob Barry Posted February 23, 2022 Author Posted February 23, 2022 1 hour ago, MaLd0n said: https://easyupload.io/vg029s That worked! Thank You! It is installed now. Only problem is i have no internet. Here is the link for my Sendme https://www.mediafire.com/file/suf3jwyv95ddi52/Send_me_KJs-iMac-Pro.zip/file Thanks!
Administrators MaLd0n Posted February 23, 2022 Administrators Posted February 23, 2022 the intel lI210 Lan have several problems for some people after bigsur/monterey -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Jacob Barry Posted February 23, 2022 Author Posted February 23, 2022 4 minutes ago, MaLd0n said: the intel lI210 Lan have several problems for some people after bigsur/monterey So what is the best fix for my case?
Administrators MaLd0n Posted February 23, 2022 Administrators Posted February 23, 2022 one realtek pci card for example -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Jacob Barry Posted February 23, 2022 Author Posted February 23, 2022 2 minutes ago, MaLd0n said: one realtek pci card for example Ok, thanks Are you able to patch my DSDT for me? or should i post it on the other page? https://easyupload.io/0flusj
Administrators MaLd0n Posted February 23, 2022 Administrators Posted February 23, 2022 https://easyupload.io/eq7qwh -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Jacob Barry Posted February 23, 2022 Author Posted February 23, 2022 43 minutes ago, MaLd0n said: https://easyupload.io/eq7qwh I think i did it right, this is all new to me. I put the DSDT file into the EFI/OC/ASPI folder on the boot drive. Also checked in OC Configurator and its in there. Is this correct? Also, just curious as to what all got patched? Thanks again for your help! I will be donating!
Administrators MaLd0n Posted February 23, 2022 Administrators Posted February 23, 2022 14 minutes ago, Jacob Barry said: Also checked in OC Configurator and its in there. Is this correct? yes put dsdt.aml in acpi folder, remove ssdt olarila and add entry dsdt.aml in config.plist save one ioreg, need some things to fix https://olarila.com/files/Utils/IORegistryExplorer.app.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Jacob Barry Posted February 23, 2022 Author Posted February 23, 2022 5 minutes ago, MaLd0n said: yes put dsdt.aml in acpi folder, remove ssdt olarila and add entry dsdt.aml in config.plist save one ioreg, need some things to fix https://olarila.com/files/Utils/IORegistryExplorer.app.zip So delete SSDT completely from folder? Reboot? And is this what youre looking for? https://easyupload.io/2vkqpl
Jacob Barry Posted February 23, 2022 Author Posted February 23, 2022 1 hour ago, MaLd0n said: yes put dsdt.aml in acpi folder, remove ssdt olarila and add entry dsdt.aml in config.plist save one ioreg, need some things to fix https://olarila.com/files/Utils/IORegistryExplorer.app.zip I added what you asked for above this post, But i was wondering if there is anything that can be done for the fan speeds? I am using a Kraken X73 RGB AIO Cooler for the cpu. When the computer goes into sleep mode the fans stop. Is there a way to control them? It is connected to a USB Header.
Administrators MaLd0n Posted February 23, 2022 Administrators Posted February 23, 2022 Cooler cpu stop after wake and don't work more? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Jacob Barry Posted February 23, 2022 Author Posted February 23, 2022 (edited) 1 hour ago, MaLd0n said: Cooler cpu stop after wake and don't work more? It comes back on after wake. But i would like to be able to change the fan speeds and check the temperatures GPU Fans not working Internet now working! Edited February 23, 2022 by Jacob Barry
Administrators MaLd0n Posted February 24, 2022 Administrators Posted February 24, 2022 2 hours ago, Jacob Barry said: GPU Fans not working gpu fans - if temp is very low fans don't start run on benchmark gpu and u see Virtualsmc with plugins for amd gpu and intel cpu temps VirtualSMC.kext.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Jacob Barry Posted February 24, 2022 Author Posted February 24, 2022 1 hour ago, MaLd0n said: gpu fans - if temp is very low fans don't start run on benchmark gpu and u see Virtualsmc with plugins for amd gpu and intel cpu temps VirtualSMC.kext.zip 129.05 kB · 0 downloads Thank you, I believe i have everything working. Were you able to fix the ioreg file? Thanks again
Administrators MaLd0n Posted February 24, 2022 Administrators Posted February 24, 2022 8 hours ago, Jacob Barry said: Thank you, I believe i have everything working. Were you able to fix the ioreg file? all seems good Just Enjoy -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Jacob Barry Posted February 24, 2022 Author Posted February 24, 2022 2 hours ago, MaLd0n said: all seems good Just Enjoy I appreciate all of your help with this! I will be donating. 1
Jacob Barry Posted March 3, 2022 Author Posted March 3, 2022 On 2/24/2022 at 6:12 AM, MaLd0n said: all seems good Just Enjoy So, every time I start up the computer. The monitors go black and will not show a signal. I will have to restart the computer a few times for the monitors to show a signal. Sleep is also not working now. Any suggestions?
Eggzin Posted March 8, 2022 Posted March 8, 2022 Motherboard - ASUS H170M-PLUS CPU - i5 7400 RAM - ADATA 8GB 2400 x 3 Storage - KINGSTON SA400S37240G Hi please help, I'm trying to install monterey but I'm getting black screen after verbose.... using internal graphic... I can't put my folder as it big. THANKS
