Hello everyone! I've found out that 10.9 somehow reads the device differently from the same DSDT file. So I basically need to modify my DSDT (adding name,ioname,compatibility injection) but i don't have much experience in dsdt editing. With a little help from old napalm it says i need to inject this:
   Store (Package (0x08)
           "device-id",
           Buffer (0x04)
                0x18, 0x3A, 0x00, 0x00
           "compatible",
           Buffer (0x0D)
               "pci8086,3a18"
           "IOName",
           Buffer (0x0D)
               "pci8086,3a18"
           "name",
           Buffer (0x0D)
               "pci8086,3a18"
       }, Local0)
   Return (Local0)
Thats explanation of temp behavior: Screen%20Shot%202013-06-15%20at%204.49.44%20PM.png
my GPU GTX 650 has almost same temp like GPU and this isn't normally because it's a Kelper GPU so in Windows around 28 30C maximum.
In 10.9...
37GPU 1500 rpm
33 CPU 1507 rpm
This is my DSDT: http://cl.ly/373m2e3w0N0D
Now who can help me to inject new IOName code...
The idea it's to regain same temps/rps fans as it in Mountaion Lion. Actually Mavericks reads a little different the values so it needs to be corrected!
Thank you very much, help appreciated!
 macOS 10.15.6
*GA-Z87MX-D3H F7 - OpenCore  | i5-4570 |HD4600 | I217-V | ALC892 | |DELL SE2416H via HDMI|
try this one
Not noticeable changes, anyway, thanks!
Is not a problem even it's running with 100-200rpm + different then ML.
Thanks!
 macOS 10.15.6
