Emrah Toprak Posted February 16, 2022 Posted February 16, 2022 Hello, can you help with the installation?Laptop Model: V15-IIL Laptop (Lenovo) - Type 82C5Processor Model: 10th Generation Intel® Core™ i5-1035G1 Processor(Core i5-1035G1)Graphics Devices: NVIDIA GeForce MX330 2GBAudio Devices: RealtekNetwork Devices:Its name is Realtek RTL8822CE 802.11ac PCIe Adapter ,QUALCOMM ATHEROS QCA9377Disk and Ram: 1 tb hdd western digital
Administrators MaLd0n Posted February 16, 2022 Administrators Posted February 16, 2022 Use EFI folder from link bellowhttps://www.olarila.com/topic/5676-hackintosh-efi-folders-for-all-chipsets-clover-and-opencore/ Check tutorialhttps://www.olarila.com/topic/20908-guide-easy-fast-and-perfect-hackintosh-vanilla-step-by-step-clover-and-opencore-bootloader/ Some Basic Information -Use USB2 port for easy installation with no remap USB -Delete old EFI folder and paste new. Don't use merge files -Don't use Drag and Drop into EFI partition. Use Copy/Paste instead -Reset NVRAM one time - OpenCore use entry "Reset Nvram" / Clover use F11 key on boot screen Bios/UEFI Configuration -Sata = AHCI mode -Secure Boot = Disable if need -CSM = Disable with AMD cards -If you have only IGPU use -igfxvesa bootarg for easy installation -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
