Hi to all I bought this laptop today to start testing mac on notebook because I already own a desktop with it. I have already had experience with the DSDT in the past but only respect to PC (desktop). For now I have applied only the T_X rename patch to override some warnings but I can't know how override the remaining warnings. Is there someone that could help me? Thanks in advance.
Specs of laptop (Fujitsu AH532):
-Chipset Intel HM76
-CPU Intel i3 2348m with HD 3000 gpu
-Memory 4 GB 1600 Mhz
I attached also the DSDT untouched.
DSDT.zip
-Chipset Intel HM76
Warnings do not affect anything.
if it is a sandy bridge what patch u want to apply ?
I don't know if it is a sandy bridge because it has sandy bridge cpu but it has also hm76 chipset that is intel series 7 chip, any advice?
dsdt is not mandatory to run mac os x it helps .. but so many users think it do miracles..is not the case
only apply the patches for what not working.. and if it exists
anyway try this one
ehci and xhci fix
hdef
pnlf
irq
lpc
function keys
is a good base to u apply others
anyway try this one
ehci and xhci fix
hdef
pnlf
irq
lpc
function keys
Thanks a lot I will make a try
OK I have an update, I installed the DSDT and all works good like sleep, also with lid closed, audio with a modification, only the intel hd 3000, sometime is slow like bad gfx acceleration, and I have a doubt because the HWMonitor app shows this okczna.jpg. Are normal this temps? Also CPUFanSpeed doesn't show the right speed, is normal this?
