Monterey using itlwm trackpad settings not showing
My trackpad is working but I dont want to have to push it down to click on something. I want to just tap it. This setting is normally in trackpad but it shows there that to turn bluetooth on and says no trackpad found. Is there away to make it where i dont have to click to select something?
Thanks,
battery working? to options trackpad appears battery need stay working
Awesome, that was the issue. I couldn't get the Atheros AR5B125 to work in Monterey so i took the laptop apart and replaced it with an Intel 7260 and I hadn't installed the battery back and all the screws I was testing it out. Thanks for the information simply putting the battery into the laptop fixed it. You're Awesome!
Now i have to figure out how to get the sound working and I think that's the last thing that's not working.
Thanks,
