Need help with HDMI sound on z490 aorus elite ac (Monterey)
Hello,
I have successfully installed Monterey 12.1 using opencore and everything is working fine except for my HDMI audio
I tried a lot of methods from different sites with no success (boot args using alcid, device properties with hackintool, Voodoo HDA, ...). Spent the whole week searching the forums and google with no luck
My sound is working through digital optic connection but it does not work on HDMI (Connected to my TV (Haier))
Motherboard z490 aorus elite ac
CPU: intel core i3 10100
iGPU: Intel UHD Graphics 630
Audio: RealTek ALC1200
Attached is my config plist, if anyone can direct me towards the solution and help to fix this problem I will be thankful
config.zip
check hackintool or github. have many patches there and u dont lose time ;)
If you are talking about framebuffer patching, I have already tried that out with different layouts with no success.
If you can point me to a specific post that can help I will be thankful
many people create patches for same processor and mobo. u just need test
Quote
            <dict>
                <data>BwCbPg==</data>
                <key>framebuffer-con0-busid</key>
                <data>AgAAAA==</data>
                <key>framebuffer-con0-enable</key>
                <data>AQAAAA==</data>
                <key>framebuffer-con0-flags</key>
                <data>xwMAAA==</data>
                <key>framebuffer-con0-index</key>
                <key>framebuffer-con0-pipe</key>
                <data>CgAAAA==</data>
                <key>framebuffer-con0-type</key>
                <data>AAgAAA==</data>
                <key>framebuffer-con1-busid</key>
                <data>BAAAAA==</data>
                <key>framebuffer-con1-flags</key>
                <key>framebuffer-con1-index</key>
                <data>AwAAAA==</data>
                <key>framebuffer-con1-pipe</key>
                <data>CAAAAA==</data>
                <key>framebuffer-con1-type</key>
                <key>framebuffer-con2-busid</key>
                <key>framebuffer-con2-flags</key>
                <key>framebuffer-con2-index</key>
                <key>framebuffer-con2-pipe</key>
                <data>CQAAAA==</data>
                <key>framebuffer-con2-type</key>
                <data>AAQAAA==</data>
                <key>framebuffer-fbmem</key>
                <data>AACQAA==</data>
                <data>AAAwAQ==</data>
                <key>igfxfw</key>
            </dict>
