Hey,
i couldnt find this in AppleALC resources ( matching layout ).
Audio works fine on my USB Interfaces, however, volume hast to be set inside playback application, no option for system sounds volume or general master volume. If i use volume scroller on my keyboard, disabled image appears.
If using Built-In analog Out, volume rocker works, but coming from other os, i was always able to control volume even for USB devices.
My question: is it normal macos behavior so ill live with it or can volume rocker be working for USB out?
audio-controls.zip
21 hours ago, MaLd0n said:
I re-checked and the layout is set correctly.
Im searching for a tool to take my audio stream, shave off like 50dB and then route it out of the system. Like a intermediate modification of the soundstream, EQ options would be appreciated too!
I guess this is not a hackintosh question but a macOS general question.
