Installed Olarila 10.8.2 from USB, HD3000 problem
Hi. I installed Olarila 10.8.2 using USB, and I removed the intel graphic kexts from the flash drive before installing because my install would get stuck at bluetoothHCIcontrol completed and therefore the install would not start. Now, I am done installing completely. Only my keyboard works, no touchpad so I am using a USB mouse. My HD3000 video card in the CPU doesn't work AT ALL probably because I removed those kexts from the USB. I used the unishit USB long time ago on the same laptop and it worked without me needing to do anything to the video card.
I have tried GraphicsEnabler=Yes to no avail can someone tell me what to do?
man if u use another thing to install and all works.. just use it...
Pleased on't get me wrong. I want to use Olarila, it seems good to me but I dont want to use unishit and that stuff. Please advise
