Monterey now successfully installed .
But my graphics card ;
MSI GT 710 2GD3H LP GeForce GT710 2048 Mt DDR3 PCI Express x16
is causing me some headache .
Simply put I can’t change the resolution .
In add. I can only boot into the OS by using the installer USB - disk .
Would it be possible to boot straight from the HDD if I’d copy the EFI - folder from the USB - disk to the HDD .
Still in add.
How can I easily make a backup of the system ; can I do this with Disk Utility ?
