GTX 1050 supported with Hackintosh? If yes, how can I enable it? Because hackintosh detects Intel HD Graphics 630 card instead of NVIDIA GeForce GTX 1050
High Sierra only. After this version u need use OCLP.
Thanks for reply @MaLd0n sir. Would you mind guiding me the steps to do or any guide link for this?
Been trying to install Ventura on my Dell Optiplex 7070 SFF using opencore with no success.
Stops at COLLECTION UUID MATCHES WITH LOADED KCS
SPECS
Intel Core i5 - 9500
32GB DDR 4 RAM
512GB SSD
https://www.transfernow.net/dl/20230518vyDUiZ0a
Hi @MaLd0n Sir, I hope you are doing good. Sorry for disturbing you.
Here is the google drive link of dump file made by RunMe app
https://drive.google.com/file/d/1FHBEpjqFFE3WSvuPHIXTI0tOAxQAgogA/view?usp=sharing
Things not working -
Bluetooth
Trackpad (USB Mouse working but laptop trackpad not working)
Graphic Card (Intel card working but Nvidia GeForce GTX 1050 not working)
Wifi
Sound (Sound working but Dolby sound not working, voice is very low even on full volume)
It would be a great help for me if anything fix
And thank you so much for your efforts
Edited by sam99eer
Ethernet is working, tried with different cable
5 hours ago, Lysed-A said:
Thanks so much for your help. This worked perfectly for installation. However I only get 7mb graphics memory.
https://github.com/acidanthera/WhateverGreen/blob/master/Manual/FAQ.IntelHD.en.md
i have two USB ports and both are USB 3.0. i disable secure boot and then i booted with my usb . i reseted nvram and then entered into mac recovery but nothing really happened . it showed deplaying text console in 10 seconds and then i come back to the same menu. btw i have HP Pavillion laptop . Hp laptop doesnt have much settings in BIOS to change just fyi. what to do.??
None of my internal drives are showing up when I try to install mac os to the laptop.
When im trying to install Mac OS Vetura in the macos installer my internal drives arent showing up
Select Disk Utility
Click on Icon with Dropdown present on left side of "Disk Utility" heading
Select "Show All Devices"
All the connected disks will be then visible
Hey I think my ventura image is broken cuz I can't get installed, it starts copying to the drive at 13 to 12 mins and then the setup just closes
U need a updated Lilu
Lilu.kext.zip
Hi, I have a doubt about the usb mapping. When I mapped all the ports and they are working as expected, do I have to remap them again when I do a clean install of another version of macOS? For example if I'm using monterey with ports mapped but i do a clean install of ventura erasing the ssd.
10 minutes ago, ru379 said:
Hi
Hi. No. Remap is same.
Need expert help with your Hackintosh?
Get professional Olarila support for:
Professional Hackintosh consulting since 2006.
Get your system properly configured, optimized and stable.
More information / Professional Support:
https://olarila.com/topic/40852-professional-consulting-for-macos-hackintosh-since-2006
