  • Sign Up
On 10/23/2022 at 9:32 PM, MaLd0n said:
never test
im using only fenvi t919 cards
Hi @MaLd0n So finally, I was able to find wifi and bluetooth cards that would work on eBay...none in my place locally = just want to confirm this will work before I buy it? Please see attachment - there is also a more expensive one with antenna...which one do you think is better?
I also don't know if I need adapter for this or not to work with my PC...my mobo has M.2 port
BCM94360CD 802.11AC WiFi & BT 4.0
Broadcom BCM943602CS 802.11AC BT 4.0
bluetooth wifi.zip
I never test it
4 hours ago, Singsic101 said:
Hi @MaLd0n Finally found a listing on a local eCommerce store in our country and bought this T919 you recommended!
good
this card is good for hacks
hmm,
I have toshiba S50-B laptop ( haswell 4200u )
as i burn the RAW file mojave to the usb all oke.
i download laptop haswell opencore.
i deleted in the EFI on the usb the efi folder, and emty bin.
i pas the efi from the zip file that i download.
i turn of the kext that i not use.
al the times the install hangs on same info.
also as i only boot with lili,whatevergreen and virtualsmc
it hangs on tect Initialized /dev/rdisk4 as a 5MB case-intensitive HFS Plus Volume ( for more than 4 houres )
what do i wrong ?
with the PC it works as i HEDT opencore past in the EFI on the usb.
past i EFI for Laptop haswell it boots not, it hangs for houres
Huananzhi x99-TF Xeon 2680V3 4x16Gb DDR4 2400 2x NVME 256GB ( Mojave )
Toshiba S50-B 4200u 16Gb ddr3 1600 BCM4352  ( Sierra stable, mojave glitched Screen )
disable csm
Hi @MaLd0nAll is going well now and today my wifi bluetooth will be delivered! Just curious, I noticed the SIP is disabled - should we leave it disabled? or can it be enabled? I don't know if SIP enabled will work fine.
Thanks a lot by the way!
u can enable with no problems
set to 00000000
  • Author
DUALBOOT PROBLEM WITH NEW RX6600XT OC
When I was in Windows and after Windows I switch to MAC, I always get a blank screen instead of the login screen, and I have to restart the computer using the restart button. After that it enters normally.... RX6600XT is OC graphics, and with the old RX580 there were no such problems... I use latest clover with up to date Kexts
Any solution?
reset nvram one time
Hi,
Did you find that problem, that after install Ventura or update from Monterey there is no ethernet hardware. I can successfully install Monterey and Ventura (if I check that I don't have internet connection).
My config is:
MSI z590P PRO
Intel I5-11600
Asus RX5500XT
Thank you
this lan card lose support
u need use kext from previous system
1 hour ago, Attila Gubányi said:
Would you please help me where can I find these kexts and which are these kext?
AppleIntelI210Ethernet.Ventura.zip
use with bootarg e1000=0
