Help with install Monterey via usb
Good evening everyone Please help me to install Monterey system via usb The thing I am missing is the EFI file compatible with MAXIMUS VIII HERO + CPU I7 7700K + graphique Intel® HD 630 Thank you in advance
I tried to install the system with EFI.Opencore.Desktop.KabyLake.zip, but the process did not work, here is a video for clarification
https://youtu.be/TvOB_HpX5_Y
I apologize for this question, as I am not an expert in this system All these steps you sent me in the picture are in the bios that i should correct
https://imgur.com/9nHM6c0
Where do I find this? easy installation on IGPUs use -igfxvesa In the bios or in cofig, plist
config.plist, nvram/bootargs
Thank you for your help
I have successfully installed the system
How to install graphique Intel® HD 630
1 hour ago, alidzcom said:
Of course, if this file is necessary
for one perfect hack is necessary
use RunMe.app
https://www.olarila.com/topic/10301-hackintosh-olarila-runme-dumper-app/
graphics use bootloader to inject
use 5912000
