VGA WORKS WHEN BOOT FROM USB...DOES NOT WHEN FROM HDD
I3 4150 + GIGABYTE H81M-S + NVIDIA 710 + VGA MONITOR
I SUCCESSFULLY INSTALLED OLARILA CATALINA IN THE ABOVE MACHINE.  INSTALLATION WAS STRAIGHT FORWARD AND NOT EVEN A SINGLE ISSUE WAS FACED . I COPIED THE EFI FOLDER FROM USB TO EFI PARTITION .  WHEN BOOTED FROM USB, EVERYTHING IS OK AND VGA OUTPUT IS THERE . BUT WHEN BOOTED FROM HDD, THE DISPLAY GOES BLANK MIDWAY AND ONLY THERE WILL BE HDMI OUTPUT. HOW IS THIS POSSIBLE .
CLOVER BOOT LOGS IN THE TWO SCENARIOS ARE  ATTACHED . I FOUND THAT THE FOLLOWING SEQUENCE IS NOT INITIATED WHEN BOOTING FROM HDD WHICH CAUSE TO BLOCK THE VGA OUTPUT MIDWAY
0:100  0:000  LegacyRegion2: Chipset/proc: 0x0C008086
0:100  0:000   Next Generation Core processors (PAM 0x80-0x86)
0:100  0:000   Test PAM1=(0x41=90, 0x5a=90, 0x81=11, 0x91=00) at chipset 0C008086
0:100  0:000  , Install = Success
0:108  0:008  BiosVideoDriverBindingStart!
0:108  0:000  BiosVideoCheckForVbe
0:108  0:000  EdidOverride not found
0:156  0:047   Edid1-
0:203  0:047   Edid0-
0:223  0:019   Edid1-
0:243  0:019   Edid0+
0:243  0:000   found Detail Timing 1366x768
0:269  0:026     0 640x480 attr=3BF - ok, edid+, 640x480, working, highest, pref=0
0:270  0:000     1 800x600 attr=3BF - ok, edid+, 800x600, working, highest, pref=1
0:271  0:000     2 1024x768 attr=3BF - ok, edid+, 1024x768, working, highest, pref=2
0:272  0:000     3 1280x1024 attr=3BF - ok, edid-
0:278  0:005     4 1600x1200 attr=3BF - ok, edid-
0:278  0:000  BV new mode: 2 1024x768
0:463  0:184   SetMode pref 2 (2) = Success
0:463  0:000  VGA Pci.Hdr.Command=6 - not enabled
0:514  0:051  VGA Pci.Hdr.Command=6 - not enabled
1:453  0:939  VGA Pci.Hdr.Command=6 - not enabled
1:459  0:006  VGA Pci.Hdr.Command=6 - not enabled
3:859  2:399  VGA Pci.Hdr.Command=6 - not enabled
PLEASE HELP
BOOTLOGS.zip
Edited by pmc
File attach
seems like usb problem or video problem
Can u tell me why the booting differs in usb and hdd with same clover version and EFI folder
