I am trying to do the installation on my Aorus Z390 card with an i5 9600K with integrated video, the installer opens normally, but the shoe me the error  "An error occurred loading the update"
I use the image Monterey Olaria without any changes, any tips to solve the problem ?
https://ibb.co/71V8PTH
Edited by Rodrigo Osinaldi
use -igfxvesa bootarg. u need create ur video patch
Thank you very much my friend, I tried to do the 2 ways you indicated and unfortunately the result was the same, curiously I see that in other cases there is no exact answer to what may be happening
