Gigabyte B550 Ryzen 9 5900x didn't work EFI Properly............
hello sir
i have a Gigabyte B550 AMD motherboard & Processor AMD 9 5900x. last 6 month i use hackintosh mac Os Big Sur 11.4 version. Now u r Olarila sit giving new version Mac OS Big Sur 11.6.1 & Mac OS Monterey 12.1. I got the Image and EFI. i make properly make Bootable USB. But this USB didn't work properly. show ACPI r error. last 5 day ill try another EFI still show same problem. I m so much tired. Pleas give me a properly Solation..i Attach a Pic.
error.rar
Edited by Rainbowrain
use efi folder from here
https://www.olarila.com/topic/5676-hackintosh-efi-folders-for-all-chipsets-clover-and-opencore/
but u need edit kernel to patch
in many cases mobo 550 need a ssdt CPUR
sir first time ill use this EFI but this efi not work. already ill try more then 10 EFI but not support not support. sir can u give me a complete EFI folder....and how do i edit this patch....???
On 11/9/2021 at 12:43 AM, MaLd0n said:
hello sir
still now have problem, don't solved is. no more EFI r not work, don't understand is it. how can i solved it ...........??? i have new problem in this that's u link. now booting start some minutes goes to monitor r auto sleepy do not back monito. at this time i unplug my power cable and new power button pc r back. so much tired
Sir MaLdOn
ARE YOU TIRED OF MY SOULUTION?
I have this motherboard B550 and Ryzen 9 Very annoyed with the 5900X.So far I have
tried at least 20 times but failed. No EFI is working in any way. Booting is stuck
every time. However, even if Monterey does not work, it is possible to install Mac
OS Big Sur with it. Sir Maldon, you seem to be clumsy and annoyed at not being able
to solve it. Otherwise you would be expected to find a solution. I gave a few pictures
and configured my PC. I hope I will get a solution if possible.
Gigabyte Motherboard-B550 Elite AC
Processor-AMD Ryzen 9 5900x
Graphic Card - AMD Redon 8gb
SSD- M.2 512gb
Ryzen 9 5900x.rar
i dont have idea about ur hack problem
good luck
On 11/13/2021 at 4:29 AM, tasco11 said:
Sir
thank u for ur support. but even smarter than this i have already got EFI. the sad thing is that is didn't work either. It seems to me that the plist configuration may need a new patch for this which i do not understand. So I want to say that is you have a PC with such a configuration, you can give me the EFI. And i uploaded the previously obtained EFI and you can keep it in your collection.
https://www.transfernow.net/dl/202111088i1wKYqx
