RobloxScriptingTutorials Mac Posted October 31, 2021 Share Posted October 31, 2021 (edited) Hi, I am trying to boot into the Olarilla Big Sur Installer but I get frozen on this screen. Please take a look at the link for the image. I have done everything correctly for example setting the correct BIOS Configs. Link to image: https://gyazo.com/36ecc9ca12c520b9b7a22a171a8890ee Then again it can get hard to hackintosh on this machine sometimes. So I will try and get a different machine from my factory to see if it works on there. But it would be nice if you could help me on my main machine. Edited October 31, 2021 by RobloxScriptingTutorials Mac I forgot to pu the image, sorry! Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted October 31, 2021 Administrators Share Posted October 31, 2021 Hey change efi folder for ur hardware https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
RobloxScriptingTutorials Mac Posted October 31, 2021 Author Share Posted October 31, 2021 Hey, what I did was go to the Vanila Images and download it from there. So I can’t access the EFI partition in my USB. So I tried formatting it and using the folder for all chipsets which you sent me, pasted the efi folder and made a new folder called com.Apple.recovery.boot then put the BaseSystem.dmg file and chunklist file in there. But the Installer didn’t show up when I booted it, like it did boot OpenCore but there wasn’t the installer it was just reset nvram and something else. Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted October 31, 2021 Administrators Share Posted October 31, 2021 https://www.olarila.com/topic/12857-how-to-mount-efi-partition-on-macos-or-windows/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
RobloxScriptingTutorials Mac Posted October 31, 2021 Author Share Posted October 31, 2021 Not gonna lie but you reply very quick, thats what I call High Quality Service! Keep it up Not gonna lie but you reply very quick, thats what I call High Quality Service! Keep it up And also it says something to do with security so I can not access the EFI Partition Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted October 31, 2021 Administrators Share Posted October 31, 2021 run as admin -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
RobloxScriptingTutorials Mac Posted October 31, 2021 Author Share Posted October 31, 2021 (edited) Thanks I can access the EFI Folder, so what shall I do now? Do I need to delete all of the stuff in EFI partition and copy the EFI folder into my EFI Partition Hey, I did paste the EFI folder and it did work but it kernel panicked. I was very close. I am not trying to be mean but I do have to go in the next hour or so, could you please reply? By the way here is what the panic looks like https://gyazo.com/ca73dd22ccfa52933d4280cc4e54790d Edited October 31, 2021 by RobloxScriptingTutorials Mac Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted October 31, 2021 Administrators Share Posted October 31, 2021 delete all files inside partition and paste new efi folder -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
RobloxScriptingTutorials Mac Posted October 31, 2021 Author Share Posted October 31, 2021 I did but it just kernel panics Link to comment Share on other sites More sharing options...
Administrators MaLd0n Posted October 31, 2021 Administrators Share Posted October 31, 2021 use bios/uefi in default just disable csm -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
RobloxScriptingTutorials Mac Posted November 1, 2021 Author Share Posted November 1, 2021 (edited) Thanks! It doesn’t kernel panic. Instead it just gets stuck at Generation SMC Report 2. I think it could be because of a kext. But I really need help, it has been my dream to run macOS Big Sur! Edited November 1, 2021 by RobloxScriptingTutorials Mac Link to comment Share on other sites More sharing options...
