Installation problem - No disk detected
Hi everyone, I'm trying to do a clean install of macOS Monterey on my laptop Lenovo IdeaPad C340, but the disk utility isn't showing up my disks, can someone help me?
On BigSur I had to add CtlnaAHCIPort.kext to see my drives but it no longer works on Monetery. Does anyone know of another kext I can try to get my drives recognized?
remove bluetooth kexts
Hi!
I've used SATA-unsupported.kext to detect my Crucial SSD on HP Pavilion 15-bc404ur.
Hope that it's help to you.
bluetooth kext not wifi
check here too
Quote
tried this and didnt work also
would you state the name of the bluetooth kext , i cant find it , i am using the olarila image as it is , i didnt add any kexts after creating the usb using etcher
2 hours ago, allmobilez said:
can you please explain how did you do that ?
I don't know what kind of bluetooth you have. For me I disabled intelbluetooth kext.
I suggest using Opencore 0.7.5 if you aren't using it.
Edited by Deihmos
