Hello guys, i have some problem.
I can boot into macOS Big Sur 11.6, Windows and Monterey (currently Beta 10) perfectly use Opencore 0.7.4 (0.7.5 beta also booted), but the thing comes after that. When I did restart or shut down from Monterey, the laptop restarted or completely shut down, no issue about shutdown and restart, but i can't move any keys on the next phase using my laptop keyboard. So i can't choose which OS i want to boot after i did restart/shutdown from Monterey. The problem doesn't exist if i restart/shut down from Big Sur. To get it working back, i have to let the OpenCore boot into other OS first, and then restart again or I have to use USB keyboard to select OS. I tried update the BIOS but no luck so far. I also tried use Clover 5141 but also no luck. If any have some idea or advice, please lemme know. Any help would be appreciated. TIA!
Here's the specs:
Lenovo ideapad S340 - 14IWL
CPU : i5-8265U
iGPU: UHD620
dGPU: MX230 (Unsupported)
RAM: 2x 4GB DDR4
Bootloader : OC 0.7.4 Release Version
macOS : BigSur 11.6; Monterey Beta10
Boot Mode: UEFI GPT
BIOS Version : ALCN33WW (v2.10)
EC Version: ALEC33WW (v2.10)
post ur efi folder here
No mean to be rude, but doesn't it feels like the problem comes from the BIOS itself? I've tried used Legacy Boot Support under BIOS and the keys are normal working, only i can't choose which OS as default boot option by pressing Cmd+Enter. Any possibilities related to EFI config?
