Hi, I have :
i5 10300H
GTX 1650 Ti 4GB
2x 8GB 2400Mhz (Don't know the brand, will provide it later if needed)
V-GEN 256GB NVME M.2 SSD PCIe Gen 3.0 x4
Intel Wifi 6 AX201
I tried to boot into Big Sur, with OpenCore 0.7.2 and Olarila's Disk Image
However,  the installation stopped in halfway (12 minutes remaining) then it just rebooted itself.
I asked my friend, he said that it was normal to reboot in halfway installation, but the problem is, i got an error when rebooting, AND i can't boot into OpenCore anymore, it was just boot right away to the MacOS Installer partition, here i will provide the error image, also the EFI folder
I tried altering the Quirks in config.plist, but that doesn't seem to be the solution.
Does anyone know the solution? Note that I didn't make the EFI folder using Olarila's guide.
I was confused with Olarila's guide, I couldn't find any EFI making guide using Windows here, so I ended up with non-vanilla-way's guide to make the EFI configuration.
If there's a EFI making guide for windows, I'll happy to use it. Thank you!
Sorry if the file is so big, i can't find a way to compress it smaller
Error link : https://drive.google.com/drive/folders/1J9XWBb5YqLk5wTulhHITavGbHesxy_OP?usp=sharing
for mobile i'm using western 750
reset nvram. use bootkey to boot
disable booter/quirks DevirtualiseMmio
