http://www.projectosx.com/forum/index.php?s=&showtopic=2304&view=findpost&p=23985
Download: http://sourceforge.net/projects/cloverefiboot/
I needed to put the keys in the MLB and ROM config.plist
	<key>RtVariables</key>
<dict>
	<key>MLB</key>
	<string>C12340002F612340M</string>
	<key>ROM</key>
	<data>000000I6Mzk6OWI6M000000=</data>
</dict>
MLB = BoardSerialNumber (don't need to be valid)
ROM = MAC address of ethernet converted to base64 (but can be a random value)
Chameleon fix
use the last enoch
http://www.insanelymac.com/forum/topic/231075-chameleon-22svn-official-pkg-installer-binaries/
in smbios
<key>SMserial</key>
<string>G88014V4XYKxxxxxx</string>
add digits to your serial until it reaches 17 digits
some info from apple about the issue
http://support.apple.com/kb/TS3970?viewlocale=en_US&locale=en_US
update chameleon fix
http://forge.voodooprojects.org/p/chameleon/source/commit/2169/
from this version new module
Install module FileNVRAM.dylib in /Extra/modules (if you have ACPICodec.dylib, must delete it)
source:
http://www.insanelymac.com/forum/topic/285102-imessage-not-working-icloudinternet-etc-working-changed-bootplist-file-and-networkplist-file-help/page__st__260#entry1882700
Looks like Chameleon also solved the problem in r2169
Install FileNVRAM.dylib to /Extra/modules (if you have ACPICodec.dylib, you have to get rid of it)
Source
Hi i've the same iMessage issue... i use Chameleon-2.1svn-r2003 as boot loader.
i don't undestand if i've to replace it with clover boot loader before, or if there is another workaround to fix server error with iMessage.
thanks
Lion 10.8.4, q6600 - p5e3 deluxe GTX 550 ti 1 gb - 8 gb ddr3 corsair 1600
use one of the last chameleon and read the tuto
I already tried to use the latest chamaleon, but I had to go back the older coz the system hang to start up
like the tuto say
2 options
use one the last chameleon with the module
or use Clover
Thanks for your fast reply.
I tried to use the latest chameleon 2169 and i added manually extra/modules folder, but system hangs in the beginning..
in attache 2 screenshots......
i read around that new chamaleon does't work with efi partition..... could be this the isuue (efi partition created by older chameleon)?
never ear that don't work in /EFI
u use only the module FileNVRAM.dylib ?
what u say only work with rev 2003 ?
how did u install the chameleon in /EFI ?
Thanks i solved in this way:
i update Chamaleon with chamaleon wizard (relese 2182);
i edited serial (17 digit) in smbio.plist (as u suggested)
i create a folded extra/modules... and added the file above;
using chamaleon wizard i remove the flag in module/ ACPICodec.dylib.
Now imessage works. Thanksssssssssssssssss
I get this message when I try to login to iMessage with my Appple ID.
I use clover boot loader.
iMessage, and FaceTime works with the Apple ID on my iPad though.
ASUS ZENBOOK UX32VD-R4010P, Intel i7-3517U, 4GB RAM, 2x256SSD, NV 620m, Windows 8 Pro, Mac OSX 10.9, Linux Ubuntu 12.04 LTS triple boot.
ethernet must be in en0
wifi in en1
I am able to use my Apple ID to download apps from App Store.
But still iMessage and FaceTime does not work.
Do you think that to make ethernet en0 and wifi en1 should fix it, please?
I have USB ethernet.
wifi in en1
if u have ethernet card.. must be in en0
and wifi in en1
u must try
Yes, I have Ethernet card. Which is USB Ethernet card.
I do not have it connected to USB now though.
What should I try to do, please?
and wifi in en1
u must try
something like this
and google this is a well know issue
