Mirone Posted February 3, 2014 Posted February 3, 2014 delete flag npci=0x2000/3000. try this: http://www.sendspace.com/file/34q5ts
momomac Posted February 3, 2014 Posted February 3, 2014 delete flag npci=0x2000/3000.try this: http://www.sendspace.com/file/34q5ts Thanks Mirone!! but where can I find that flag? or you already deleted for me?
momomac Posted February 3, 2014 Posted February 3, 2014 Thank you so MUCH!!!!!!! The mic is working now. but I lost the up/down volume control. it's no longer workings. what should I look for? Thanks again!!! i have tried everything out there and I couldn't figure it out. what was the issue if you don't mind?
Mirone Posted February 4, 2014 Posted February 4, 2014 Do not understand the audio from the microphone in this system preferences / audio / microphone.
stez Posted February 23, 2014 Posted February 23, 2014 Hello Mavericks 10.9.1 on toshiba laptop here. I used this code to patch my dsdt Device (HDEF) { Name (_ADR, 0x001B0000) OperationRegion (HDAR, PCI_Config, 0x4C, 0x10) Field (HDAR, WordAcc, NoLock, Preserve) { DCKA, 1, Offset (0x01), DCKM, 1, , 6, DCKS, 1, Offset (0x08), , 15, PMES, 1 } Method (_DSM, 4, NotSerialized) { Store (Package (0x16) { "AAPL,slot-name", Buffer (0x09) { "built-in" }, "codec-id", Buffer (0x04) { 0x69, 0x02, 0xEC, 0x10 }, "built-in", Buffer (One) { 0x00 }, "name", Buffer (0x0F) { "Realtek ALC269" }, "model", Buffer (0x10) { "Realtek ALC271X" }, "device-type", Buffer (0x25) { "High Definition Audio Controller" }, "layout-id", Buffer (0x04) { 0x1C, 0x00, 0x00, 0x00 }, "device_type", Buffer (0x06) { "Sound" }, "subsystem-vendor-id", Buffer (0x04) { 0x86, 0x80, 0x00, 0x00 }, "hda-gfx", Buffer (0x0A) { "onboard-2" }, "PinConfigurations", Buffer (Zero) {} }, Local0) DTGP (Arg0, Arg1, Arg2, Arg3, RefOf (Local0)) Return (Local0) } Method (_PRW, 0, NotSerialized) { Return (Package (0x02) { 0x0D, 0x05 }) } } and this kexts taken from osx86 http://www.osx86.net/files/file/34-applehda-alc269-for-mavericks/ Internal speakers works but not headphones and mic even if audio work I got lot of errors about AppleHDAController, logs attached. (there are lot of other errors but for now I just to want to make audio works) So.. about the layout-id.. where can I change it? In the dsdt? If I understood right, IORegistryExplorer take the layout-id from the DSDT right? And if I change the layout-id, what id I've to put? Compared with what? Hope that somebody could help me to make audio totally works Attachments: IOReg: http://www.sendspace.com/file/dbbbe4 Report.htm: report file from AIDA64 with all my laptop specs: Report.htm.zip Boot log: log.log.zip DSDT: DSDT.aml.zip (I've tried to use Mirone DSDT in this post about 10.9 http://Olarila.com/forum/viewtopic.php?f=18&t=2734&start=20#p34263 but it doesn't work at all. I take only some parts of HDEF section of the DSDT attached there)
m.gbt Posted February 24, 2014 Posted February 24, 2014 layout-id is applied to HDEF device inside _DSM method, in the DSDT. Check for the DSDT patches section: http://Olarila.com/forum/patches.php You have to choose your layout-id according to the patched AppleHDA, this is the only thing to watch out. It varies on the taste of who made the patch. It could be 28 (1C), 12 (0C), 4, 1... Or even other numbers... The kexts provided by Mirone always include a readme file telling you which layout-id to use. Mavericks 10.9.2 Retail When you ask for support, remember to tell the bootloader you use
stez Posted February 24, 2014 Posted February 24, 2014 ok, so I just put here my dsdt 'cause right now I can only use internal speakers using this kext and the code suggested http://www.osx86.net/files/file/34-applehda-alc269-for-mavericks/ DSDT dsdt.dsl.zip AIDA64 report Report.htm.zip Hope that somebody could help me, thanks!
